Pics of my ES
hey guys thanks again for the kind words. To answer some questions... yes tint is an upcoming mod... looks very strange to me with non-tinted windows.
The auto dim mirror I installed when I put a new windsheild in... we ran the wire under the headliner and down the pillar...
The cluster i took the brown window off and cut a piece of clear plastic the same shape and then atatched it to the cluster trim... it looks pretty awesome... LLT is lexus Lighting tech he does the LED retrofits for our cars and hes awesome! No more dead needles! and very very bright! everyone who rides in my car asks about the cluster
The nav I had to cut a piece of ABS plastic to create a trim piece for it since they do not make a dash kit for that kind of deck for the ES300. After I had cut it the shape to fit the avic i sanded it down so it was smooth and then I painted it with krylon semi-gloss paint... it matches the climate control plastic perfectly...
in the pics of the nav... it looks like my climate control lights are white... but they are not... they are green like the normal lights i dunno why the pics came out like that... haha...
Lexucanafer
I guess you've become CL's most recent 2nd gen. ES300 guru with all the work you've put into your ride!
So is LLT a local California guy, or did you have to ship your cluster off somewhere to have done?
Thanks for the great pics. I want to see some more after you get the tinting done. Probably won't even recognize the car. Tint makes such a difference.
Looks awesome!
So is LLT a local California guy, or did you have to ship your cluster off somewhere to have done? It looks great, BTW.
And yeah, I will definitely take some more pictures after I get it tinted and install the struts and springs. Im hoping that the springs dont drop it tooooo much, because I like the smooth ride...
I am thinking about doing 30% all around. I know its illeagal here in Cali, but I also am not a big fan of the non-uniform tint look. IMO it looks best with the same percetage on all the windows...
Nice pics , my cluster unit was just sent out this this week to be fixed by them . However , once the cluster was pulled out , the car barley wants to idle . Did you have the promblem? I am still curious , where did you get your mirror from? What make and model?
The mirror is the standard gentex mirror that is in a lot of the new toyotas. You can purchase this mirror directly from gentex or you can pull it at a junk yard from pretty much any late model lexus or toyota. I ordered mine through ebay for around $45 and it supposedly came from a 02-06 ES300.
here is a link to one exactly like mine: http://cgi.ebay.com/ebaymotors/02-Le...spagenameZWD1V
one thing i would like to add about this mod... it is not a direct clip onto your existing mount, to do this mod you need to remove the old mirror and mount and attatch this one... when i did mine i was getting a new windsheild anyway... so i just told them to glue this one on instead of the OEM one...
nope all you need is a power source, but I was reading about the install from some of the SC guys who have done the mod, and they suggest not to use your map lights for the power... so i ran mine under the headliner and down the pillar and connected it to a ground and powered it from the ignition wire like you would if you were hooking up a deck... cause you dont want it to be on after the car is turned off...
