rims on a lexus
Old 01-12-07, 11:39 AM
adus lexus
adus lexus's Avatar
Default rims on a lexus
does anyone have 19's or 20's on their es300 without doing any modifications. is it also possible to put 19's without any modifications?
Old 01-12-07, 01:35 PM
Two bit
Two bit's Avatar
19's are pushin it without being able to rub. 19s usually will come 8" and wider and 8" rubs for some people. I'd go with an 18" wheel to be honest, no need for 20" or 19" you'll have a terrible ride.
Old 01-12-07, 09:03 PM
trukn1
NELOC Mod
trukn1's Avatar
This issue has been addressed many times before. From what I remember 19 can fit on an ES but it does require some modification (shaving fender, pulling, rolling). Other members have complained that the ride was really bad. Would not go above 18, if you want to keep a truly decent ride. Try using the search and advanced search features on this site and you will be able to find alot of information which has been discussed before.
Old 01-12-07, 11:03 PM
charley240
charley240's Avatar
19" is ok. if you get the right tire size, which would probably never go over 225 youll have a similar diameter with 15" on a 205/65/15. but, there is of course less rubber, therefore the harsher ride. but hey, you have to pay to play. for you i will post pics when i get my 19*9 trafficstar wheels. they should be in very shortly. since you started another thread about 19" wheels again, i would assume you havent done any research about offset and wheels related stuff.
Goodluck
Charley
Old 01-12-07, 11:48 PM
chrispy
chrispy's Avatar
Goodluck
Charley
i think this is the 3rd thread from that guy asking about wheel fitment for his ghetto lexanis. which trafficstars did you get btw? i'm looking forward to seeing them. are you going to run any stretch? 9 inch width is pretty ballsy since the widest i've seen on the ES is 8.5.
Old 01-13-07, 12:02 AM
charley240
charley240's Avatar
yeah, including the one below that was accidentally started, that is either 4th or 5th. i am getting the rtv's. yes a stretch is in need. i dont see how anyone can go without stretch on coilovers and being lowered. on strut/spring combo yes, i believe its possible. now, the only thing i am worried about is the rear. it may or may not clear the fender. i am at about 95% assurance that it will. and i might have to go even lower offset for my plan: max negative camber, and dumped. im taking my car in this monday to have all the fender lips cutoff. and the bodyshop that i plan to go to is going to work out a deal with me, because i am not rich, to have my full Auto Couture kit w/fogs put on and rear end collision repaired.
Old 01-13-07, 06:17 AM
Maxx941
Maxx941's Avatar
AC KIT? Man you are one lucky guy. I can't wait to see how your car will look.
Old 01-14-07, 10:49 PM
Rollin'ES3
Rollin'ES3's Avatar
u guys think going with 20s is too much for an es?
Old 01-14-07, 11:12 PM
chrispy
chrispy's Avatar
i think 19's look the best. 20's are way too big.
Old 01-15-07, 08:17 AM
MoreMGD32
MoreMGD32's Avatar
egh it all depends......i had 20's on my 95 lexus and in retro spec. i think it was over kill, it gave the car that modded/aftermarket look and some bling but made it look ghetto/raised look at the same time. I would stick to 19's on any model 97 and up. the body designs and lines imo dont blend right for anything larger unless you have a body kit. As far as the 95 and below models i wouldnt go anything larger than 18's. My 95 is in the gallery with 20's if it helps anyone with future modding.........
All in all, those size rims will come at much work and much expense to upkeep. For 20's you will have to cut your fender lining completely(1995 and below), the fender wall will cut through the sidewall of your tires(1995 and below), and you'll have roll your fenders(any year).....
for 19's you should be able to get away with just getting a low profile tire if your wheels aren't too wide. or at most roll the fenders(models 97 and up)
my two cents
Old 01-15-07, 08:51 AM
charley240
charley240's Avatar
oh man, another man victim of the 20" rim club. man is that overkill or what. i know that the difference b/w 19-20 is tiny, but like moremgd said about the excessiveness of the 20". people tell me that im crazy spending so much money for some 19" wheels, when i could have spent half the amount for 20" and be a tad bit larger. but i tell them that it is too big, its that little bit of difference that matters.
Charley
McFlury
06-15-18 07:00 AM
ajochums
10-11-11 08:06 PM
iceberg06
08-16-11 07:33 PM
ldc
01-07-08 10:20 AM
tmasta
05-29-01 12:51 PM
Quick Reply: rims on a lexus
