lexus es300 wheel fitment
Old 02-16-07, 11:54 AM
E-Z ES300
E-Z ES300's Avatar
HMMM, im not sure if mine are staggered but i mean i think a car just looks and sits nicer when it is staggered even though it is pretty pointless with a FWD. As long as they sit on the car i wouldnt mind whether its staggered on a FWD or not.
Old 02-16-07, 02:11 PM
charley240
charley240's Avatar
staggering is very bad. learn about oversteer countersteer. then youll see why. personally, i wouldnt do it. and the rims you pictured? why do they have a bmw centercap. because more than likely the bolt pattern is going to be off. btw, those are some nice wheels. a believe they are portofino's.
ok, i just did the estimates for 18*8.5 +40et. it should fit, only if youre still on shock/struts. if youre coilover then barely.
goodluck
Charley
Old 02-16-07, 08:23 PM
Choas
Choas's Avatar
What in simple terms is staggering going to due and is there any way to compensate for it and what if i put the big ones in the front
Old 02-17-07, 09:23 AM
E-Z ES300
E-Z ES300's Avatar
Staggering is when the back tires and/or wheels are wider then the front wheels. I know about the oversteer and understeer, personally i love oversteer (when its on purpose).. i HATE understeer!!!(i dont think anyone likes it).... im still thinking about getting them or not. Thanks for doing the calculating to see if they will fit, now im that much closer to ordering them
Old 02-17-07, 09:36 AM
Choas
Choas's Avatar
So if the tires wider in the back will it oversteer or understeer.
Old 02-17-07, 07:16 PM
chuckb
chuckb's Avatar
Originally Posted by djdoughboy
I have 18x8.5 LS430 wheels on my 92 ES and they fit just fine, I am running 18x40x225 rubber,
those wheels are 7.5 wide, not 8.5.
Old 02-18-07, 05:37 PM
Maxx941
Maxx941's Avatar
I wouldn't do the staggered setup either, unless your getting a great deal on those set of wheels i'd pass on them
Old 02-18-07, 11:13 PM
Choas
Choas's Avatar
1050 for the set 500 miles on them if it just over steers i can handle it
Old 02-19-07, 06:41 AM
E-Z ES300
E-Z ES300's Avatar
Yeah like i said oversteer you can take care of, not to much the understeer, its just annoying. If you stagger you have much better traction in the back and not so much in the front your probally looking to have understeer but it wont be an unbareable amount because i dont think to many people like to or even can take to hard of turns in your ES's, correct me if im wrong...
Old 02-19-07, 12:28 PM
djdoughboy
djdoughboy's Avatar
Bolt pattern: 5 x 4.5
Wheel size: 18 x 7.5
oops yep sorry
Old 02-19-07, 01:09 PM
Choas
Choas's Avatar
The tires are going to be 2 inches wider in the rear. So basicly i will have to turn the wheel a lot more to turn.
Old 02-22-07, 08:52 AM
E-Z ES300
E-Z ES300's Avatar
Thats correct, but it wont be a substantial amount. Its kinda like if your car comes stock with 16's and you upgrade to like 19's your speedometer is off by some small number, but nothing big....
Old 02-22-07, 08:55 AM
E-Z ES300
E-Z ES300's Avatar
Choas... Im not sure if you understood me right, i'm not sure if you understood "understeer", its when say its wet or snowy out and you go to make a left turn and you turn the wheel to the left but the car keeps on going straight... You wont have to turn the wheel more to make a turn, the amount of rubber thats touching the ground in the back wont make a difference in how wide you take a turn...
Old 02-22-07, 03:27 PM
Choas
Choas's Avatar
Ok I think I get it now . I'm not planning on putting these on in the winter so the snow won't be an issue. For in the rain it will basicly be like my old mustang with bald tires in the rain. So I can def. deal with that also after using the maita tire calulator site i found that these tires are actually i tiny bit smaller than my stocks so the speedo won't be off by much.
Old 01-20-15, 05:42 AM
Citylightz
Citylightz's Avatar
I have ls430 rims on my 97 es300 but rubs in the rear tires are 245/45/18 all way round
Ls430 18inch oem rims fit good but rubbing in the rear tires are 245/45/18 don't want to use spacers would a smaller tire help?
Quick Reply: lexus es300 wheel fitment
