New front breakes - no 56k
Old 01-15-07, 04:55 PM
vin 78
vin 78's Avatar
Default New front brakes - no 56k
I normally hate Brembo and EBC, but I got one HELL of a deal on these brakes. Although my pads are still pretty new, my rotors are REALLY old, its almost as old as the car. So instead of having them turned, I'm installing these. Also, Since these rotors are new and and my pads are old and likely warped, I'll install the new pads as well.
Jack up and put the car over jackstands - safety first!
Take off tires.
Remove only the bottom 14mm caliper bolt.
Wiggle around and swing it up and remove pads.
Place caliper above the rotor for now. Don't let it hang.
Remove the two 17mm caliper bracket bolts. This bracket is SUPER tight, so be careful and use a lot of leverage. Note to tighten it with a torque wrench, check your repair manual for specs.
Pull out the old rotor and install the new one. Hand tighten some lug nuts on to the rotor so it will be straight while you install the bracket and pads.
Reinstall the bracket.
Old 01-15-07, 04:56 PM
vin 78
vin 78's Avatar
Transfer the brake sensor (bottom left of new pad) from old pads to new ones, note there's only one for each side.
Install the pads.
Wrap the brake master cylinder with a rag so it won't spill out when forcing in the caliper piston.
Buy this $5 caliper tool, its worth every penny. Use one of the old pads and place next to the piston and twist the ****. This will force back the piston.
Pull and twist this thing (i'm not sure what's its called) out. Yes I have really ugly finger nails...
Notice that its dry. This can interfere with the caliper movement as well as reduce the longevity of the pads.
Wipe clean and re-grease.
Do the same for the upper thing that's on the caliper.
My picture is messed up, sorry.
Be sure to reinstall every bolt. Check and double check that the bolts are tight. You don't want to find that out when you are out on the road.
Be sure to use a torque wrench when reinstalling the wheels (80ft.lbs. and 60ft. lbs. for wheel locks).
Do the same for the other side and you're done.
Keep in mind that "performance " brakes require a break in period. So be sure to take it easy on them for the first few hundred miles.
Be sure to pump on the brake pedal a few time before driving the car, this will ensure the pads are engaged with the rotors. Your car will not stop immediately if you don't
Old 01-15-07, 06:42 PM
chrispy
chrispy's Avatar
Very nice write up. I'll be referring to this thread when my rotors go bad.
Old 01-15-07, 07:33 PM
amf1932
amf1932's Avatar
MODERATORS......MAKE THIS THREAD A STICKY.
Excellent vin 78!
Old 01-15-07, 07:39 PM
LXMN
LXMN's Avatar
LOVE the write up. The rotors make the wheel well so much cleaner looking. Can not stand the way our rotors rust up and look crappy like that. Brings the car down a notch. I will refer to this in the spring when I change out my rotors and pads. Nice again.
Old 01-15-07, 07:40 PM
vin 78
vin 78's Avatar
Excellent vin 78!
Thanks guys.
Hey I spelled "brakes" wrong in the title note to self: proof read!
Old 01-16-07, 06:05 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Nice brake upgrade....looks really good!
Old 01-16-07, 10:14 AM
lexusk8
lexusk8's Avatar
Awesome write-up vin, and great job taking photos of the brake DIY project!
I will add this thread to the DIY master thread, and to keep the newbies and potential DIYers in the know, I will stick this thread for a while
Old 01-17-07, 05:53 AM
cino135
cino135's Avatar
how much we looking for the new pads and rotors??
once again, classy write up!!
Old 01-20-07, 12:04 PM
Maxx941
Maxx941's Avatar
Excellent Write-up, I will be sure to use this soon.
Old 01-29-07, 08:55 AM
lexus4jess
lexus4jess's Avatar
Thats what I need on my car.sloted rotors. Good info.
Old 06-04-07, 02:34 PM
2000ES300
2000ES300's Avatar
so basically brake pads just float on the surface of the rotor?
Old 06-04-07, 02:37 PM
amf1932
amf1932's Avatar
Exactly.
Old 05-25-09, 06:55 AM
Maxx941
Maxx941's Avatar
I knew I'd use this thread at some point. Thanks VIN and CL
Old 04-06-10, 03:16 PM
aJedi
aJedi's Avatar
uummmm....I can't see most of the pics in this write-up.
Quick Reply: New front breakes - no 56k
