Old 01-07-15, 12:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: General Overview
Print Wikipost
Automotive Recalls and Technical Service Bulletins
Old 11-06-01, 12:27 PM
CPerez100
CPerez100's Avatar
Default Automotive Recalls and Technical Service Bulletins
If you need info regarding other year, let me know...
TSB Number Issue Date TSB Title
AX001R-01 MAY 01 Trunk - Retrofit Internal Release Kits
BO005-01 MAR 01 Seat Belt - Revised Tongue Plate Stopper
AX001-01 MAR 01 Internal Trunk Release - Retrofit Kits
ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization
PG017-99 DEC 00 Vehicle - Year 2000 Readiness Disclosure
EL008-99 DEC 00 Engine Immobilizer System - Precautions
PG005-00 JUL 00 Service Manual - Page Corrections
AC001-00 JUL 00 A/C - Compressor Maintenance During Storage
ST004-00 MAY 00 Steering Wheel Nut - Torque Update
PG001-00 APR 00 CA/50 State Certified Emission Control Label Ordering
AX001-00 MAR 00 Towing - Dinghy Towing (Four Wheels On the Ground)
TC003-99 SEP 99 A/T - Fluid Recommendations
TC001-99 APR 99 Drive Shaft - Grease Revision
AX003-99 MAR 99 Dinghy Towing Guide - With Four Wheels on the Ground
SS002-98 DEC 98 Tools - Installing Rivet Nuts
BR003-98 AUG 98 Front Brakes - Grinding/Squeaking/Groan Noise/Vibration
TC003-98 JUN 98 A/T - Fluid, Type T-IV Introduction
BO001-98 APR 98 Seat Belt - Extenders Available
EL005-98 APR 98 Cigarette Lighter - Service
EG001-98 APR 98 MIL ON DTC P0441/P0446 EVAP System
BO007-97 OCT 97 Seat Belt - Extenders Availability
SS001-97 SEP 97 Brake Booster - Push Rod Gauge
AC001-97 SEP 97 A/C - Musty Odor
TC001-97 APR 97 A/T - A541E Harsh Engagement Shock
BO003-96 DEC 96 Seat Belt - Extenders
BO004-96 DEC 96 Front Door Glass - Air Leak Noise
EL00496 OCT 96 CD Changer - Will Not Eject Magazine
AU00196 AUG 96 AM Radio - Static Noise on Weak Stations
AC006-96 AUG 96 A/C Control Assembly - Service Parts and Troubleshooting
EL003-96 AUG 96 Wireless Door Lock - Service Information and Diagnosis
TC00296 JUN 96 A541E A/T - Direct Clutch Modification
AC000396 JUN 96 A/C Compressor - Maintenance For Stored Vehicles
AC00196 MAY 96 Ambient Temperature Display - Reads Minus 22 Degrees F
EG00296 APR 96 Exhaust Pipe - Protector & Clamp Available Separately
PA00296 APR 96 Paint - Refinish & Formula Codes
PG00296 APR 96 Emission Control - Label Order Form
BR00296 MAR 96 Front Brake - Groan Noise
B095007 DEC 95 Moonroof Panel - Revisions & Service Tips
B095008 DEC 95 Moonroof Panel Wind Noise
BO95006 NOV 95 Seat Belt - Extentions
SS95002 OCT 95 Engine Support Bar - Improvements
PA95002 SEP 95 Paint - Repairs On Polyurethane Bumpers
BO95004 SEP 95 Wiper Insert - Available Separately
BR95002 AUG 95 Brakes - Introduction of Shim & Fitting Kits
TC95004 AUG 95 A/T - A541E Harsh Upshifts
TC95003 AUG 95 A540E A/T - Clutch Disc Improvement
PG95003 JUL 95 Vehicle - Standard Bolt Torque Specifications
PG95002 JUN 95 Emission Control Labels - California/50 States
PG95001 JUN 95 Service Manual - Correction Information
EG95004 MAY 95 Water Pump - Seal Improvements
TC95001 MAY 95 A/T - Fluid Leak From Bolt Hole
EG95003 APR 95 Radiator & Upper Tank Assemblies - Changed
EL95004 APR 95 Wiper Motor - Circuit Breaker Inspection
SU95003 MAR 95 Wheel Alignment - Specifications
EL95003 MAR 95 Door Lock Key Transmitter - Improvement
AC95001 MAR 95 A/C - Refrigerant Leak Detection Service Hints
SU95002 FEB 95 Suspension - Squeak/Groan Noises
EL95002 FEB 95 Battery Maintenance - of In Stock Vehicles
EL95001 FEB 95 Passenger Airbag - Replacement Procedure
ATRATB294 JAN 95 Axle Nut/ Lug Nut Tightening Specifications
TC94002 NOV 94 A540E A/T - Secondary Regulator Valve Modifications
BO94004R NOV 94 Power Door Window - New Wire Type Subassembly
POL9417 OCT 94 Brake - Repair Warranty Policy
TC94001 SEP 94 A540E & A541E A/T - Overdrive Clutch Bearing Update
BR94003 JUL 94 Brake Pad Kit - Expanded Ordering Options
PG94002 JUN 94 Coil Spring Spacer - Removal During PDS
PG94001 MAY 94 Emission Control Label - Order Form
BO94001 MAY 94 Seat Belt Extender - Availability
AC94-001 APR 94 A/C - Approved/Non-Approved Alternative Refrigerants
SS94-001 APR 94 Special Service Tools - Essential & Available
BR94-001 FEB 94 Brakes - Vibration/Pulsation Causes
PA94-001 FEB 94 Exterior - Paint & Refinish Codes
BO93-009 NOV 93 Body - Preventing Water Entry Onto Passenger Side Floor
SU93-004 OCT 93 Alignment - Specifications Updatte
SU93-003 SEP 93 Front Stabilizer Link - Set Nut
SU93-002 SEP 93 Rear Suspension - Member Set Nut
PG93-004 MAY 93 A/C - Ozone Depleting Substance Caution Labels
PG93-003 APR 93 Vin Plates/Certification Labels - Replacement
ATRATB078 NOV 91 How To Use A Pressure Gauge - Automatic Trans.
PGI004 SEP 91 Recycled Coolant - Usage Recommendations
PGI003 AUG 91 Front Coil Spring Spacers - Removal During PDS
BODY026 AUG 91 Body - Permanent Type Protective Wax Coatings
ATRATB028 OCT 90 Engine Testing With A Vacuum Gauge - Auto Trans.
ATRATB9002006 FEB 90 Automatic Transmission Fluid
ATRATB8930 OCT 89 Automatic Transmission Math Part 2
ATRATB8927 SEP 89 20 Steps To successful Auto Transmission Repair
ATRATB8923 AUG 89 Automatic Transmission Math Formulas
ATRATB8754 SEP 87 All Automatics - Front Bushing Wear
ATRATB8748 AUG 87 Metal Sealing Rings - Automatic Transmissions
Old 11-06-01, 12:31 PM
CPerez100
CPerez100's Avatar
That's for ES300 , 1994
Old 11-10-01, 08:43 AM
The Ikon
The Ikon's Avatar
Exclamation
Get one for the 92' SC400....
The Ikon
Old 11-10-01, 10:06 PM
CPerez100
CPerez100's Avatar
The Ikon
Bulletins for 1992 Lexus SC 400 V8-242 4.0L
Service Bulletins
TSB Number Issue Date TSB Title AX001R-01 MAY 01 Trunk - Retrofit Internal Release Kits
AC002-99 MAR 99 A/C Lines - Rattle Noise
AU92-003 SEP 98 Nakamichi Radio Displays FFFFF
AC001-98 APR 98 A/C - System Retrofit from (R-12) to (R-134)
AU92-001 FEB 98 Radios - Popping Noise when Adjusting Volume
AC00496 JUL 96 A/C Control Assembly - Service Parts
EL95006 NOV 95 Radio - Static Noise On Weak AM Stations
SU95005 OCT 95 Rear Suspension - Clunking/Rattling Noise
BO95003 APR 95 Moonroof Panel - Service Tips
EG95002 APR 95 Radiator - Reservoir Tank Sub Assembly
BO95002 APR 95 Front Seat Back Protector - Revised
BO95001 FEB 95 Front Door - Contact or Popping Noise When Opening
BO94003 SEP 94 Instrument Panel Register - Replacement Procedure
AU94-001 JAN 94 The CD Changer Skips
ATRATB191 OCT 93 Failsafe Modes - Computer Shifted Transmissions
PG93-005 AUG 93 Repair Manual - Corrections
BO93-005 MAY 93 Seat Belt Extender - Available
93005 MAY 93 Seatbelt - Extensions Available
AC93003 APR 93 A/C System - (R-12) Leak Inspection Procedure
EL93003 APR 93 Combination Switch - New Double Lock Connector
BO93003 MAR 93 Front Seat Cushion Shield - Improved
EL93002 MAR 93 SRS - Service PrecautionS
SS93001 MAR 93 Spring Compressor - Precautions
AC92003 OCT 92 A/C - R12 and R134A O-Ring Identification
TC92002 OCT 92 A540E A/T - Production Modification
EN92002 OCT 92 Engine - Pinging Explanation In Owners Manual
EG92-002 OCT 92 Engine - Pinging (Spark Knock)
POL9304 OCT 92 Warranty Policy - Reimbursement for Testing/Diagnosis
EG92001 SEP 92 Water Pumps - Improved Durability
PA92-002 SEP 92 Paint - Refinish Codes
ATRATB132 SEP 92 Intermittent Electrical Problems
PA92001 JUN 92 Paint - Guide and Repair Procedures
BO92004R APR 92 Sunvisor - Improved Hinge Retention
AC92001 APR 92 A/C - Panel Illumination Improvement
BO9204 APR 92 Sunvisor - Improved Hinge for Better Retention
B092003 MAR 92 Seat Belt - Extender
WARR9215 MAR 92 Vehicle - Cellular Phone Warranty Freight Reimbursement
WARR9214 MAR 92 Warranty - 30 Day Claim Submission Policy
AUDIO92001 FEB 92 Audio - Pop Noise When Adjusting Volume
AUDIO92002 FEB 92 CD Changer - Skips/Will Not Play/Reads `Err'
WARR9213 FEB 92 Warranty - Operation Code Add Request Form
WARR9212 FEB 92 Cellular Phone - Motorola Phone Number and Address
ELEC010R FEB 92 Battery Maintenance - For Vehicles In Dealer Inventory
EL92-002 FEB 92 Speed Sensor - Inspection Corrections
EL92002 FEB 92 Speed Sensor - Inspection Procedures Revised
WARR9210 JAN 92 Battery - Revised Testing Procedures
AUDIO007 DEC 91 Audio - Tape & CD Button Illumination Logic Change
WARR9209 DEC 91 Tires - Replacement Warranty Claims
WARR9208 DEC 91 Warranty - New FAX Machine Number
WARR9207 DEC 91 Warranty - Activity Report Schedule
ELEC011 NOV 91 ECT & ECU - Service for New Double Locking Connectors
BODY031 NOV 91 Luggage Compartment Lock Assembly - Modified
AUDIO006 NOV 91 CD Changer - Operation Information
SUSP004R NOV 91 Wheel Alignment - Repair Manual Correction
PGI005 NOV 91 Emission Control Label - California Information
BODY028 SEP 91 Front Seat Cover - Wear
BODY015R SEP 91 Paint - Prevention/Repair of Acid Rain Damage (Revised)
BODY029 SEP 91 Paint Protection - New Vehicle Washing Schedule
PAINT004 AUG 91 Exterior - Paint & Refinish Formula Codes
AUDIO005 AUG 91 Audio - SC400 System & Component Information
SUSP004 JUL 91 Alignment Specifications - Manual Correction
ACC002 JUL 91 Mudguard - Installation Procedures
PAINT002 MAY 91 Exterior - Paint and Refinish Formula Codes
BODY022 MAY 91 Front Spoiler - Installation Procedure
BODY015 DEC 90 Paint - Prevention and Repair of Acid Rain Damage
Old 11-10-01, 10:10 PM
The Ikon
The Ikon's Avatar
Thumbs up
Perez, thanks... Do you have the recall info too?
Old 11-10-01, 10:24 PM
CPerez100
CPerez100's Avatar
actually, I'm waiting for some guy from Lexus dealer to call me back and send it over to me, but he also told me that it may not possible to be distributed to the public. (I dunno if that's true )
If I do get it, I will posted as soon as possible....
Old 11-10-01, 10:43 PM
The Ikon
The Ikon's Avatar
Arrow Thanks anyway
I'm sure that recall info is not private. I will try to find it too. The SC4 had a recall I'm sure, but I forgot what it was(I will check with the dealer if you do not find it).
The Ikon
Old 06-17-03, 05:17 PM
642jdub
642jdub's Avatar
Do you have one for 1992 ES300?
Thanks
Old 06-17-03, 05:49 PM
amf1932
amf1932's Avatar
Default 1992 ES300 TSB
TSB for 1992 Lexus ES300
PG002-02 JAN 02 Certification Label - Replacement Availability
PG003-02 JAN 02 VIN Plate - Replacement Availability
PG003-96 MAY 96 Service Manual - Publication Correction Informations
PG00396 MAY 96 Wiring Diagram - Manual Update
PG95005 DEC 95 Publication - Correction Information
BO95006 NOV 95 Seat Belt - Extensions
ATRATB294 JAN 95 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
BR93-002 OCT 93 Front Disc Brake - Groan
PG93-009 AUG 93 Air Bags - Repair Manual Corrections
PG93-008 AUG 93 Correction To Repair Manual
SU93-001 JUL 93 Rear Suspension - Squeak or Groan Noises
BO92010 JAN 93 Front Seat Headrest - Rattles
BO92009 DEC 92 Sun Visor - Rattle Noise
SU92002 NOV 92 Rear Stabilizer Bar Bushing - Squeak Noises
BR92001 OCT 92 Rear Disc Brake - Squeak Noise
TC92001 SEP 92 A540E A/T - Parking Pawl Improvement
AX92-001 JUL 92 Mudguard - Installation Instructions
EL92-001 JAN 92 Fuel Gauge - Innacurate Readings
ELEC001 JAN 92 Fuel Gauge - Reads Inaccurate
ATRATB078 NOV 91 A/T - How To Use A Pressure Gauge
BODY027 AUG 91 Front License Plate Mounting Bracket - Installation
ATRATB028 OCT 90 A/T - Engine Vacuum Testing
ATRATB9002006 FEB 90 A/T - Choosing the Right ATF
ATRATB8930 OCT 89 A/T - Math Part II
ATRATB8927 SEP 89 A/T - Twenty Steps To Successful Repairs
ATRATB8923 AUG 89 A/T - Math Formulas Part I
ATRATB8754 SEP 87 A/T - Front Bushing Wear
ATRATB8748 AUG 87 A/T - Slipping or No-Shift/Metal Sealing Rings
Old 06-17-03, 11:22 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
The TSB's are great...but if there are any future requests, can the requests be PM'ed or e-mailed nextime?
BTW, you can find alot of these TSB's on alldata.com and a few other sites.
Thank you!
-Mod.
Old 06-18-03, 04:53 PM
642jdub
642jdub's Avatar
Thanks for the link to www.alldata.com. Definitely helpful. What can you do with the TSB number? Is Lexus suppose to fix the problem for free?
Old 06-19-03, 09:26 AM
lexusk8
lexusk8's Avatar
With TSBs on hand, you may or may not get a problem fixed for free on your car, but Lexus shouldn't charge you for the full price of the job. TSBs are probably the next best thing to warranty work.
Old 08-13-03, 09:44 AM
Bluesman
Bluesman's Avatar
Sorry to bring this post up from the dead, but this post has my curiosity. What is the intelligent way to handle this information ? I bought my 94 ES used. Is Lexus obligated to correct these issues ?
Old 08-13-03, 01:52 PM
iNdoMeX
iNdoMeX's Avatar
EG002-98 MAY 98 Charcoal Canister - Modified
what about this one, cuz i just had to get my charcoal canister replaced like a year ago and had to pay like three to four hundred bucks for it or somethin....can i do anything or no?
Old 08-13-03, 02:54 PM
lexusk8
lexusk8's Avatar
I think that's almost like trying to use a grocery coupon with an expiration date... the TSB won't help you because you already paid for the service job on your car.
Quick Reply: Automotive Recalls and Technical Service Bulletins
