Simple suspension question
When do you know it's time to change the shocks and/or struts? The stealer *says* the rear ones are worn and I should replace them, but is there a way to test and see if they really need replacement (without taking them apart of course)?
Oh yea, my '96 has 117,300 miles on it now
I've only had to change the front ones and when I had them done, I dont even know if they were needed. I did it cause there was some clunking noise.
Never had to change the rears yet and the car has 219K miles on it.
It may need it but I don't notice so I just keep driving it.
I know its bad to keep driving with worn struts because it adversely affects handling and puts stress on other parts that weren't designed to handle the stress.
The suspension kinda does absorb most of the road impacts, but I've heard a creaking noise whenever I go over speed bumps. Maybe it's a cold weather thing........
I used to like having dead shocks/struts because it reminded me of having a stiff @ss ride that JGTC cars have.
The struts didn't even creak anymore and I'd have to avoid pot holes and go super slow on speed bumps.
Someone else claims fixing the noise by using a lubricant on the rear struts. See https://www.clublexus.com/forums/sho...d.php?t=259355
problem solved: took out the rear seat to gain access to the rear struts and popped off the plastic cover covering the strut mount; sprayed some lithium grease and the noise is gone. while i was at it i also lubed up my sway bar bushings.
ive been told, a general rule of thumb is to shake your car rapidly so its rocking side to side. Then, let it go and if it rocks back and fourth more than 4or 5 times then your struts are nearing replacement
The one thing I've noticed with suspension noise is that the strut can still function properly but the strut top has a part in it that when it gets loose it moves around making a tin sound. If anything, get the quick struts from advance, it only takes 20 minutes per strut and they work great. Good Luck!
Not side-to-side. You should bounce the car up and down, and if the car doesn't stabilize right away (think >> a bouncy 1970's Town Car or Caddy), then your shocks/struts are worn out.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
Replace all the suspension ahrdware at one time. Rubber mounts, struts & springs all tend to wear about the same time. Say 10 years, 100,000 miles. After that, save your money to toss all of it at one time. There's no point in having good struts on old springs & mounts.
mb12345
14
08-09-20 01:33 PM
