Occaisional Fuel leak in engine compartment
I have a friend with a 2000 ES300. Three times since she bought it in September 06, it has had a fuel leak in the engine compartment. It only happens at startup, and it doesn't leak any more if you shut it down and restart the car. If you leave it running, it will drip off the drivers side of the engine at about 1 drop per second.
It has been to the dealer three times, and it is going on its third week there this time. They don't seem to have a clue what to do. They have replaced the injector o-rings twice, and are just wanting to give the car back to her without doing anything.
I have seen several other threads on fuel smells and some others on leaks. Anyone else battled a leak like this? I suspect a pressure regulator not doing its job, but you would think that if a line has split, it would leak all the time. It is almost like something has to fail to make the pressure go high, and maybe it leaks out the connection of the hose to the fuel rails. But when the pressure is normal, the leak is gone.
Any advice on what it might be (please, no advice on "don't take it to those quacks!") greatly appreciated.
Steve
Wichita, KS
Steve
Wichita, KS
Thanks for the suggestion. I did take a look at the pulsation damper after the car was at the shop and the big cover had been removed. It was dry, and there wasn't any evidence of a leak there.
I gave my friend a list of things I thought the dealer should do. She asked if they would like to see it, and they said "Sure." I quoted a few things from a Chilton manual, and their service manager called her back and said that I obviously had no idea how the fuel system works. Seems he doesn't either. Friggin idiot. Amazing. It has had fuel leaks, and they won't put a pressure gauge on it to see what the pressure really is. All they know how to do is hook up a code reader, and start the car.
As to the commonness of the issue, I don't know. But, go to the "Maintenance" section and see how many threads there are on "fuel smell". I don't think I saw one where there was a resolution posted, but there seemed to be a lot of reports of fuel smell and some of fuel leaks under the hood.
Steve
Steve
Did it again. This time, it was the pulsation dampener. They previously replaced the hose from the filter to the fuel rail. This time, got pictures and video to show the dealer.
Good thing, because when it was started the next morning, no leaks. Ever seen a pulsation dampener leak, then heal itself?
Steve
Steve
Yes I have! my pulsation dampener does it about once every three weeks and its pissing me off. I would replace it but dont know how to get it off, the space in there is so tight. Any suggestions on how to get the dam thing off. This is on a 97 es. Thanks.
