brake fluid changing
For those with ~10 year old ESs, have you changed your brake fluid?
Also, is it stated anywhere officially by Toyota/Lexus that it should be changed at a certain interval (years?)?
Every 60,000 miles
Transmission Fluid Flush/Change
Spark Plugs Change/Tune-Up
Brake Fluid Flush/Change
Power Steering Fluid Flush/Change
Battery Check/Change
Originally Posted by Lexus Owner's Manual Supplement
Change the brake fluid every 30,000 miles or 24 months using FMVS No. 116 DOT 3 or SAE J1703 brake fluid.
Ditto. Brake fluid should be changed every 3 years on any vehicle. It's not the fluid, it's the presence of water & air.
Dot 3, or dot 4 in our case. Less you're a rich **** & can justify buying 5.1.
im looking to flush my brake fluid (lately the brakes have been feeling kind of spongy). i found this item on the net that looked pretty interesting:
http://www.motiveproducts.com/02bleeders.html
has anyone had any experience with this product?
Had it done recently. Unfortunately, at the stealer for $125........but I dont have the tools, expertise, nor time to do such things myself. I say change it every 2-3 years (not mileage-based), since the fluid absorbs moisture over time.
If so, is ATE Super Blue a top choice?
