Official ES Aftermarket/OEM Wheels Thread
#301
Rim Brand and Type: Speedy Wheels O2 FIN RS
Rim Size f/r: 18x7.5
Rim Offset f/r:+45
Tire Size f/r: 225/40/18
Suspension Setup: Everything Stock
Comment On Ride: Smoother ride, Less steering wheel vibration
Fender Modifications: none
Any other comments: Planing on lowering in the near future and painting brake calipers red to complement the red pinstripe
Rim Offset f/r:+45
#303
tiguy99 (06-22-19)
#308
#309
Had my 92 ES300 since April 2009 and so far I'm running the silver IS300 17" wheels with 215/50/17 GoodYear Eagle GT, and hub centric 10mm rear spacers with 10mm longer studs. Suspension is fairly stock other than Tokico HP strut inserts, SuperPro poly dogbone mount bushing, sway bar bushings, and Energy Suspension control arm bushings from the Camry. There is some slight rubbing on the rear quarters due to the tire being a little meaty cause it has a rim guard. Will roll it when I get a proper set of wheels with lower offset, 17x9 or 18x9 +15 or 20 offset since I want more tire.
#311
#315
Rims: Fierro Pheonix 20's
Front tires 245/35x20
Rear tires 225/35x20
Only mod I know for sure is
spacers on the back springs
Got the car recently and don't
Trust what previous owner told me
He did .
Only rubs with a car load of fattys ona pothole filled road
More pics soon to come
He did .
