Official ES Aftermarket/OEM Wheels Thread
#317
I've went thru every single page on this thread. I must admit the SEXIEST ES on here was the black one with the SC430 rims!!!! WOW!!! Very silky smooth look ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
.... The combination looked flawless IMO!!
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
#319
Rim Brand and Type: UNKNOWN
Rim Size f/r: 18X8
Rim Offset f/r:+38
Tire Size f/r: 225/45 R18
Suspension Setup: CAMBER ADJUST -3MM MAXIMUM IN REAR WHEEL
Comment On Ride: COMFORT QUITE BUT THE WHEEL WAS RUB AND WHEN DRIVE ON WAVE ROAD OR POT HOLE CONDITION
Rim Size f/r: 18X8
Rim Offset f/r:+38
#323
Alright guys, so I've got some rims I'd really like to get for my ES. They are 2010-2013 Factory ES350 rims 17x7 with 215/55/17 tires on them. I was wondering if those would be able just be put on with no mods. I don't know the offset of these rims but I'm assuming that since my factory tires are 205/60/16 I shouldn't have any fitment issues, but I rather clarify this before buying them
#324
The speedometer will be mis-calibrated, when your traveling 58.6MPH on the speedo, your actually doing 60MPH. You'd also be loosing 2.3 miles for every 100 miles traveled on your odometer.
The 17x7 rims should fit, but you may or may not need a spacer for the 215 series tires to clear the rear struts in the rear. I tried my 17x7" Lexus ES rims with 215/55/17 tires on my Solara (same suspension / wheel setup as ES) and I had barely 1 or 2 mm of clearance between the tires and rear struts.
#325
Yes I forgot to mention that I had a 3ES, but I will go ahead and look a little further into whether or not the spacer will be needed. Thanks for the tips though I appreciate it!
#328
I intend to do that ! Any idea where I can find the chrome bulbs? I did a search on eBay and it seems there selling the whole corner units .. not just the bulbs on there own
#329
http://www.ebay.com/itm/P21-5W-1157-3497-7528-AMBER-CHROME-HALOGEN-BULBS-PAIR-/191110889527?_trksid=p2054897.l4275
Here's a link to the ones that I purchased about a month ago. I'm happy with how they turned out, and they're still working great.
#330
