ES300: Replacing Cluster Backlighting Bulbs
#226
Trying to figure out bulbs for cluster, need bulb size for indicator lights (Backlighting bulbs are 24s according to Tanninauto, but after calling them they refuse to give me the number for indicator lights {O/D, ECT, etc.} weird.)
Anyone know?
Anyone know?
#227
24? I don't know what that is. Some bulbs are either T5 or T10, also known as 74 and 168/194. Do NOT replace the airbag light with an LED this will trip an SRS code which is hard to clear. Best thing is to pull the cluster and have a look. Again a warning do NOT turn the key to ON with the cluster disconnected same deal you'll get an SRS code.
#228
Their reply here:
Edit: indicator lights are definitely not t10 or t5.. those are way too big
#229
![](https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/615x676/capture_0d09a23685a77ded19db82f646834f3f1a2340c0.png)
#230
Having a really hard time getting the right side odo/trip and reset buttons clip unplugged. been at it for over an hour. anyone know what Im doing wrong? I tried needle nose to squeeze it and having no luck.
#231
Why are you trying to remove them? Do they twist off?
#232
They are a part of the trim piece that must be removed before the cluster can come out. I managed to flex the piece enough to get it to come out and just let it hang by the wires after trying to unplug it for nearly 2 hours. Not sure why mine will not unplug.
#233
Hi and very informative. Will this procedure also work for the 93 LS400? My needles and warning lights are all working but no backlight at all.
#234
I’m still confused on how to change out my back lights. I want it where my speedometer is all blue basically I’ve gone and changed out the bulbs I thought would do the trick but that was only the shift gear bulbs. I drive a 2000 lexus es300 someone please help.
