es300 wiring diagram
after connecting the new reciever, i get no power to it, engine starts. i tried swapping the acc and ignition wire, still didn't work, ground wire is #11 white with 1 dot. why is it like this?
Dude Wire's #4 and #1 are all you need from the factory harness. These are the power wires. Why did you think #11 is the ground? Just run the ground of your new deck to the body of the car.
Hope this clears thing up. Let us know how it goes!
Later
---92Lex
Later
---92Lex
the diagram you gave for the ignition +12 was wrong for my 95 lex. The +12 ignition was the blue wire with pink stripe. after connecting that, i got power and then started wiring the speakers, all is working good now. I don't know if it's your mistake or just a different wiring from Lexus or what.
I forgot what pin number the +12 ignition was but, i just glad that this shiznit works. Installed this when it was snowing freezing fingers, i went through hell man, but it was worth it, thanks very much for the speaker diagram, I thank you so much 92lex. You just don't know man.
![Talking](https://www.clublexus.com/forums/images/icons/icon10.gif)
Originally Posted by 92lex
I guess I was too slow but here it is any way.
I just went to circuit city and they told me i would have to bypass the amp by cutting the input wires and output wires and splicing them together....did anyone have to do this when installing their aftermarket headunit..?
So far i have connected the blue with red stripe wire to the red (power) on my alpine
white wire (with one dot) ground to my black ground wire on my alpine
and the gray wire (constant 12v) with the yellow (battery) wire on my alpine...the alpine lit up, but when i tried to get sound from the speakers...nothing. The alpine actually started to heat up also
Also, I have no idea why but my turn signals dont work...the light bulbs work but the signals dont for some reason...ive checked every fuse...everythings fine. Do you think it's because my whole climate control/radio is out?
As for the turn signals. I can't be sure on the ES, but I believe it is because you disconnected the hazzard button connector. Once you put that back in it sould blink again.
hey..yea my turn signalss..that was the problem i had disconnected it and didnt realize it (b/c it's connected to the Air/AC system) Umm but yea..still tryin to figure out where the speaker wires are that went into the stock head unit?
Here's my own tutorial/writeup...it's a little more clear plus i obtained the colored wiring diagrams from the manual
https://www.clublexus.com/forums/sho...d.php?t=210521
Hey, I'm new. I came in because I have a wiring problem; grounding of the wire from fuse box to the radio, on my ES300 1997. Line draws 600 mAmps until I pull the fuse. So I assume the wire is grounded enroute to the 'box'. The radio works fine, so the wire is probably touching a grounding point. Without the diagram, it's a tough haul to trace a wire. The diagram would be a great help.
So far, this has been one of the most confusing web sites I have come across. I now Club Lexus has access to 1997 ES 300 wiring diagrams because I have seen your post outside of Club Lexus on Google search.
I don't understand why I can't put ES 300 wiring diagram in the Search and get some reply. Help and guidance would be appreciated. Golfcluber
Are you having a specific problem such as your battery going dead? The stereo does draw power obviously, nothing abnormal about that.
If a power wire was touching ground it would draw far in excess of 600 milliamps.
Here are the only EWD I could find regarding the radio and its ground. Hopefully this helps.
http://imageshack.us/photo/my-images/20/b3wc.jpg/
http://imageshack.us/photo/my-images/694/rd68.jpg/
For some reason they wouldn't post here, just copy and paste the url.
*also this is for the 1997 es300
Last edited by PuReChaos; 06-29-13 at 06:54 PM. Reason: pictures weren't showing up
Thanks for the help. The problem is that there is a 600mA draw on the radio fuse line when the radio and ignition (and everything else as far as I can tell) are off. That seems strange. Any thoughts?
The wire is not touching a grounding point because if it did the fuse would be blown or the wire would be burned up. The question by Lexus2000(post #25) is very relevant and would be helpful if addressed.
Hello, I want to use my cd changer wires to connect aux for phone changer is not working anyways and my tape is hooked up to sirrius,i will get a cd player later but for now can someone please show me a diagram of which wire is what to the cd changer thanks i am new prob wrote in wrong place.
Hello,You are the only one I have found with this info,Can you please tell me which wires are which for the cd changer the a clip plan to cut it in my trunk and add an auxiliary since the changer broke.Thank You
