power steering leak
Old 04-22-07 | 03:53 AM
huerdo623's Avatar
huerdo623
Default power steering leak
I have a power steering leak and don't know where it is coming from
Old 04-22-07 | 05:58 PM
92ES5sp's Avatar
92ES5sp
Cool
Check your high pressure hose first and the pump itself is probably leaking too. What year is your car? From 92-94 the 2 speed cooling fan is driven by the P/S pump also. 95 and up have electric fans.
Old 04-22-07 | 10:52 PM
huerdo623's Avatar
huerdo623
its a 92 I checked the connections i.e the 2 hoses leading away from the pump to where they connect, and i tightened those all down and still the leak. I will check the high pressure hose in the morning, thanx for the help
Old 04-23-07 | 04:11 PM
lexusk8's Avatar
lexusk8
It could be just plain old wear and tear on the high pressure hose. That happened on my wife's 1998 Corolla so my friend and I replaced the pressure hose, drained out the old fluid and replaced with new fluid. Took about an hour to do the job.
Old 04-23-07 | 04:15 PM
92ES5sp's Avatar
92ES5sp
Cool
How much did you pay for your new hose for this 98 Corolla, Lexusk8?
Old 04-23-07 | 04:25 PM
lexusk8's Avatar
lexusk8
I paid somewhere around $57 for the hose from Advance Auto Parts. Also paid between $5 and $7 for the Valvoline PS fluid.
Old 04-23-07 | 06:12 PM
CUMan's Avatar
CUMan
Unfortunately, Lexus places a real high value on their ES high pressure power steering hoses.
I had that hose replaced on our 94 ES in March. The cost was $400.00, including labor. The part alone is $325.00 at www.lexuspartsonline.com.
At this same site, the cost on this hose for a 92 model is $284.00.
Old 04-26-07 | 01:00 AM
huerdo623's Avatar
huerdo623
Are you kidding me,284 man and that is what the problem is .There goes the tsx retrofit
Old 05-12-07 | 03:58 PM
LexNScotts's Avatar
LexNScotts
Well, I just had the power steering leak on my ES 300 fixed and it cost over $700. I needed 3 different hoses. I trust my mechanic so I just had it done. I haven't really noticed any problems since except a few drips here and there but I'm not replacing fluid every 3 days like before when it wasn't fixed. Good luck
Old 05-13-07 | 08:33 AM
sayan's Avatar
sayan
I have been having the same issue with my 94 ES300 for months now.. got the high pressure hose replaced. All was fine for a while... until there was a sudden loss of all steering fluid...
went to my local Firestone where i got it fixed last time.. they can't locate the actual leak.. so i am running on a trace dye for a few days.
Any ideas on what could be issue now... my hunch is that the bottom of the reservoir is cracked...
Old 05-13-07 | 03:58 PM
92ES5sp's Avatar
92ES5sp
Smile
Check your 2 lines that feed the cooling fan. The hydraulic cooling fan is run by the P/S pump. Firestone might have overlooked that.
Old 05-14-07 | 04:43 PM
huerdo623's Avatar
huerdo623
finally,after replacing hose after hose I found the hose it is leaking from,the hose that goes to the fan from the pump.
Old 05-14-07 | 08:03 PM
92ES5sp's Avatar
92ES5sp
Smile
Told ya
(need more characters)
Old 05-15-07 | 12:52 PM
13loody's Avatar
13loody
I replaced the power steering pump when I replaced the engine. The old one was leaking. Somehow a part of it got bent, which caused the leak. Luckily the engine I ordered came with a working pump
Old 05-22-07 | 03:38 AM
huerdo623's Avatar
huerdo623
where can I get this hose from or is there an easy way to fix it?
Quick Reply: power steering leak
