ES300 1992 - Running rough
Old 04-22-07, 06:22 PM
rstep1
rstep1's Avatar
Default ES300 1992 - Running rough
One thing that is going on is that my car idles really rough, once I get going it runs fine but idles very rough, I have removed and cleaned out the AIC Valve already, that did not seem to fix the rough idle, it also hesitates when I first press on the gas (it has always done that). I am thinking that I may have to change the fuel filter or something, it always hesitates instead of excelerating immediately when hitting the gas. I have ran some BG 44K thru the fuel system. Any ideas on any of what I have explained.? )
Old 04-22-07, 06:33 PM
92ES5sp
92ES5sp's Avatar
Cool
You may have a clogged EGR valve so i would check that.
Old 04-23-07, 07:05 AM
rstep1
rstep1's Avatar
Thanks for the tip, I will take it off and check it.
Old 04-23-07, 05:23 PM
Pheonix
Pheonix's Avatar
Cool
Vacuum leak.
Old 04-23-07, 06:22 PM
maniax
maniax's Avatar
sound like a misfire
Happened to me before. I thought i had a vacuum leak so i looked all over the car like a madman for a leak but didnt find nothing
finally found out it was a dead injector.
i only had 75k miles at the time but i did seafoam like 2 days before that so i guess the carbon deposits clogged up my injector.
Start pulling the electrical connectors on top of the injectors. If you pull one, you should feel the difference like the car wants to die out. If it doesn't make a difference then that means that cylinder is not doing work. and go from there.
Vsierra
03-15-18 07:17 AM
Alexbenz
07-14-12 09:08 AM
myztikal47
09-08-06 12:32 AM
rstep1
07-16-06 05:45 PM
tvd51
02-04-04 05:29 PM
Quick Reply: ES300 1992 - Running rough
