Which is the right trans cooler line from this pic
Which cooler line do I pull from the radiator to flush my tranny using the ATF pump naturally to flush tranny? Also, what is the piece I have outlined in the pic... it has a little oil seepage and was curious.. Thanks
![](http://home.comcast.net/~jchrisf/trans.jpg)
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
The skinnier line on the bottom is what you hook up to, the larger diameter hose is for the cooling fan which is driven by your P/S pump. And the can looking thing is an inline P/S fluid filter.
The line on the left that I have marked This Line is the one I pull off and put into a drain pan to drain the old ATF while starting the engine and letting the AT push it out for me?
Basically whichever hose is hot is what you want to hook up to
Cool.. thanks for the info... what about that leaky PS filter can... just check the connections or replace it?
