i need help asap please!!! jerking?
Old 04-30-07, 09:00 PM
blazin3gen
blazin3gen's Avatar
Default i need help asap please!!! jerking?
I need help my car is running like total **** it feels like im driving manual transmission in first gear when i take off in the morning....it does it all the time now it jerks like as if im letting the clutch out to fast then theres a loss of power takes the car awhile to get acceleration....
i dont know what is wrong with the car does anyone have any suggestions?
Old 04-30-07, 09:04 PM
Rollin'ES3
Rollin'ES3's Avatar
wat year is it, and how many miles u got on it?
Old 04-30-07, 09:28 PM
blazin3gen
blazin3gen's Avatar
its a 1992 with 180k on body but 70k on new "used" engine
Old 04-30-07, 09:52 PM
esucaris1
esucaris1's Avatar
does it clear up when it warms up? If it does you might need to check the cold start enrichment.
Old 05-01-07, 05:27 PM
blazin3gen
blazin3gen's Avatar
yes it clears up the jerking that is..but still feels like it has loss of power
what exactly is the cold start enrichment? and where is that located?
thanks u so much!
Old 05-01-07, 06:26 PM
esucaris1
esucaris1's Avatar
its on the passenger side of the intake but first fuel injection is not somthing for the mechanically inclined if you have a shop that you deal with you should take it there let them know whats happening... it could be somthing as simple as a fuel filter... however there are specific tests and tools needed to be performed to determine the exact problem... however if you feel you are capable I recomend you download a service manual before you proceed there is a link if you are interested...
Old 05-01-07, 07:00 PM
92ES5sp
92ES5sp's Avatar
Cool
And dont rule out silly things like a plugged exhaust or binding brakes/ E brake stuck on.
Being a 92 there is a whole list if things that could be wrong. Bad/ fouled plugs from oil leaks, timing way off, fuel pressure below spec, low/ uneven compression.....etc etc etc.
Could be something as simple as a TP sensor. Take it a shop and have it checked out.
Old 05-01-07, 08:48 PM
swifty562
swifty562's Avatar
180k milages on the tranny.. when was the last time you had a tranny fluid changed?
these tranny are made to last... depending how often you change your fluid and how hard you drive.
Runway91
05-16-13 05:08 PM
imprtLEXUS
Performance & Maintenance
12-19-06 06:02 PM
ynvme
02-02-06 09:31 PM
Quick Reply: i need help asap please!!! jerking?
