Power Steering
Check:
Fluid level/leaks
Belt tension
Power steering pressure switch if above are good
The switch is supposed to send a signal to the ECM when steering at low speeds or idling, and the ECM will bump up the IAC to raise the idle.
Fluid level/leaks
Belt tension
