tackle the timing belt
Well this weekend I will be installing my timing belt, water pump, idler, and tensioner pulleys for my 93ES300... I have all the parts, and downloaded a manual... I also had to make a type of spanner wrench to hold the cam gears and crank from turning when loosening and tightening the pulleys... Now all I need is a day off...
I fabricated mine out of 1" bar stock 1/4 " thick by 1 ' long... cut and welded to a y shape drilled 3/8 " holes on the ends, and 1 1/2" long 3/8 bolts welded in the drilled holes
i guess i'll try that... if not im going to ask a mechanic... because right now i'm doing a motor swap... my old engine is already out and i'm changing all the hard stuff and replace everything that needed to be replace before i drop the new motor in.
like.. water pump...tension...belt....sparks...rear engine mount (a must!! )
Well I had to make a second spanner wrench for the crank... I made it out of the same materials exept for the 2 bolts were 5/16" dia. by 1" long... I smeared a little engine grease from the oil pan on the front of the crank pulley and pressed a sheet of paper to the front of the pulley to give me the location of the bolt holes... here is a pic of the plate before cutting it out and drilling the second hole... also have to weld the handle on and the bolts in the holes...
![](http://i159.photobucket.com/albums/t135/esucaris/spanner002.jpg)
Well I hate to admit defeat... however the crank bolt kicked my butt... 3 feet of breaker bar nada... towed the car to friends shop $60... We tried impact guns 1/2" and 1" nada... I can say the spanner wrench worked perfectly lol... I did however replace the waterpump and idler pulley and changed all the plugs thanks to the diy write up by lig the combination of extensions and swivels worked perfectly
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Yea mine was like that. I sprayed some PB Blaster on the crank bolt than used a 1/2" impact and burped it in the forward direction and back about 5 times or so and it came off.
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
I just jam a breaker bar against the ground & tap the starter one time as shortly as possible.
1.1kw electric motor geared down a ton > impact driver lol! Besides. If you were to ever stall the electric motor anyways, it'd generate 3-4x it's typical torque output @ 0rpm.
Anyways. Nice job fabricating tools!
Sounds like you have done that a few times... I sure would like to get that bolt out... I have 15 yrs of auto repair under my belt so its very hard for me to succumb to the dealer... Its always nice to learn a new trick... I will give it a try thanks...
