The long awaited Is350 rims on an Es
First off, i would like to thank chaos for all the info that he had provided. for this reason, i would not get an is350 rims no longer. lol. through all that trouble and headache dude.. i'm suprise your car is not dented. i would of exploded.
but thanks for sharing.. sorry to hear the problem. hope everything works out for you.
UPDATE: Yesterday ground little bit off the section of the rim that was rubbing. At this point I won't be able to do a drop due to the 3mm of room between the rim and strut. The only way I see it working is if I can find a strut that is a tiny bit smaller in diameter. Then I would have room to do a drop.
*UPDATE* Finally just cut about another inch off the fenders which totally eliminates the black rubber strip which I have to custom cut and glue on. That makes it about an inch and a half removed to reduce the rubbing. Again for anyone thinking about these rims I would HIGHLY suggest against it!
alexkidd
02-09-17 05:56 PM
RITlexus96
11-24-13 08:26 AM
HarrierRX300
02-09-04 09:49 PM
