Window Motor?
My problem is that the windows doesn't work anymore no up no down luck its stuck close to closed...opened the door panel and the motor works in all but the cables and pulleys are what have given..anyone know where to get one? i've found this site but it doesn't look complete
http://www.******************.com/sh...xus/es300.html
That looks like its just the motor itself that you would attach to the railings etc...
Go on ebay and look for an entire window regulator set. You should be able to find one on there. Good luck . Aligning the windows is the only thing thats a ***** about this xD
no wonder i couldn't find it been searching for wrong thing, thanks for the help i really needed that...my lucks bad this weekend...radiator blew yesterday, so i replaced the radiator , thermostat and a coolant sensor and the ***ch still overheats .. in under a year i've replaced the water pump, alternator, timing belt and both front axles
turbosix
11-02-07 05:47 PM
