Should I got with bigger tires on my 92 ES300 with these rims?
Rims are 18" and tires are 225/35/18. Will those look funny and leave a big gap or should I just stick with them. If not, what tire size would be best?
Wow can't spell, go with. Not got. oops.
My stock tire size is 205/65/15. If I stick with my tires it says my speedometer reading will be 5.1% to fast. If I get 225/40/18 tires then the speedometer will be 1.6% to fast. So is it worth buying different tires?
For 205/65/15 the closest match is 215/50/17.
You can check the recommended wheel using this tire calculator.
http://www.miata.net/garage/tirecalc.html
jgmcs
03-04-07 08:39 PM
