transmission
transmission
i got a 2000 es300, tranny unfortunately died. i need to know which tranny would be interchangeable with this car, because teh 2000 tranny is not the same as the 97 or 98s, because when i dropped my tranny pan, the filters are diffrent and everything, takes a diffrent type of fluid also. so i just want to be sure thank you
-Smitty
You might be able to acquire a used transmission off of a 2000-2001 ES300 in a junkyard or salvage yard. Or you could try one from a 2000-2001 Toyota Camry, Avalon or Solara since the engine and transmission are pretty much the same. That's pretty much the extent of what you can do for replacing your old tranny. My tranny failed on me when I had my '01 ES, but thanks to the extended warranty I had at that time, I was able to get a remanufactured one from the dealer for a discounted price.
Here is a list of trannys for Toyota/Lexus,
This appears to be the U140E,
http://transtec.com/selector_guide/Lexus.htm
http://transtec.com/selector_guide/Toyota.htm
-Smitty
