just got the siverstars
Old 07-31-07, 02:40 AM
tuan92129
tuan92129's Avatar
Thats weird, my fogs come on with my low beams.
Anyways, Light output actually DECREASES with the silver star lamps because it has a coating on the bulb that decreases output.
I bought my (chinese) HID kit on ebay for $135 and its been working flawlessly for almost a year.
Old 07-31-07, 05:03 AM
RXGS
RXGS's Avatar
we always have the fogs on, there a lot more lights, or maybe it just seems that way
Old 07-31-07, 06:28 PM
RXGS
RXGS's Avatar
we finlly drove at night with them, and my mom asked why the lights were so much brighter, and i told her, thanks for telling me to get the silverstars rather then those cheesy ebay ones
Old 07-31-07, 11:17 PM
3000's Avatar
I don't know about the H7s, but the 9006s were not that much of anything. The color may be changed but brightness wasn't all that. That's why HIDs was the only option for me to achieve higher output of light... also because I wanted the color without losing light to a filter like the halogens.
Old 08-01-07, 10:25 PM
Lexucan
Lexucanafer
Lexucan's Avatar
If you do the 9005 conversion mod on the silverstar highbeams (which don't have the coated cap on the tip) you can use em as your lowbeams and the light output is about 70% brighter than your typical halogen lowbeam bulbs. I couldn't believe the difference in lowbeam light output after I did the mod.
Old 08-02-07, 08:35 AM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Question
To make sure I understand you - after this 9005 conversion you're able to drive around with all 4 headlamps on at once? If so, that's interesting and I'll have to search for "9005 conversion."
Old 08-02-07, 11:17 AM
3000's Avatar
The modification: you can use your old high beams, or go buy 9005 silverstars. Then you could modify the harness/plug and plug it in your 9006 low beam slot. So now you have 4 9005 bulbs. High beams are still gonna be regular. Low beams are a lot brighter now.
Old 08-02-07, 07:03 PM
13loody
13loody's Avatar
I thought doing the 9005 conversion damaged/destroyed the wires with the extra wattage going through them.
Is there any other downside? I don't want to drive around with my high beams basically on, but I assume the lens on the low beam prevents this from being the case. Am I correct?
Old 08-03-07, 08:10 AM
Lexucan
Lexucanafer
Lexucan's Avatar
The increase is 10W from low beam bulbs to high beam. From what I've researched and experienced myself after doing the conversion, the extra 10W is not enough to do any harm, but it sure increases visibility!
Since I did the mod (about 4 months ago) NO ONE coming the other way has ever flashed their lights which is a definite indication to me that running high beams bulbs as low beams does not affect oncoming drivers...as long as they are aimed properly.
And to do the mod, you don't have to make any modifications to your harnesses or plugs. You just have to do a bit of modding to the high beam bulbs themselves so they'll fit into the low beam housings.
Old 08-03-07, 03:10 PM
13loody
13loody's Avatar
Lexucan, how long have you had the 9005 conversion? I'm assuming the 9005 bulbs last just as long as a 9006 would correct?
I'll probably use my sister's 92 Camry XLE as the guinea pig Her output is the worst and that's after I cleaned the headlights.
Old 08-03-07, 08:06 PM
Slooooooow
Slooooooow's Avatar
Talking
Let us know how it goes!
Old 08-04-07, 07:45 AM
Lexucan
Lexucanafer
Lexucan's Avatar
It says right in the post above - about four months. And I see no reason why the 9005 bulbs wouldn't last as long as the 9006.
Here is the link to the instructions I used for modding the bulbs. It's got some nice pics of the process.
Your sister will thank you!
Old 08-04-07, 10:00 PM
13loody
13loody's Avatar
I'm sure she'll love it. I also have to replace her cluster lights. They just burned out. Time for some LEDs
Old 08-05-07, 03:42 AM
draikonz
draikonz's Avatar
Default Silverstars Photo's on 2nd gen ES
I've had silverstars before I had upgraded to my xetronic HID's a while back ago. I'm uploading a couple photo's in this topic since i've seen it awhile for reference to those that are considering purchasing the silverstars.
My thought on them, is that the light output on the road is generally increased, and the bulbs look whiter. But still have the look of halogen in general slightly. But look a lot whiter than stock. It shines on the road real well and most people will be more satisfied with halogens. But to each their own opinon. Heres the photo's now. Sorry I don't have any photo's of them actually shining on the road though
2UX31 YM
11-21-15 06:30 AM
RTIS250
Lighting
03-30-11 11:28 AM
DarKnight
Lighting
01-02-07 08:08 AM
dasenzasian
10-22-01 09:45 AM
Quick Reply: just got the siverstars
