"Turbo" noise coming from under the car?
So yeah, its the fuel pump. Anyone know how much those are to replace? Seems like an easy job(warn me if it isnt).
SO! Today i was cleaning the engine bay, and i opened up my diag port... And there is this nasty *** orange/cream goo all over it. I touched it and it was very sticky. Anyone have any clue as to what this crap is and if its bad???
Fuel pump...
First of all you want to depressurize the fuel system. Remove your fuel pump fuse from the engine bay and start your car until it wont start due to lack of fuel.
Yank out the bottom cushion of the back seat. Disconnect the harness going to the oval shaped cap on the right side. Remove the phillips head screws on the oval shaped cap and remove it. You may need a decent sized wrench to remove the fuel pipe going into the next cap, along with a 10mm socket to remove the bolts holding the cap down. After that its plug n play, you just take out the old one and dip the new one in. Then follow these directions in reverse!
Thank you all for your input, it has been quite helpful. Now i wanna know how much a fuel pump is and where i can get one for a good price. Also when i replace the fuel pump do i have to replace anything else? Isnt it possible to depressurize the system by opening up the fuel cap and opening the flapper door?
Well that would be very bad. I found this item right here... http://cgi.ebay.com/ebaymotors/2-2L-...spagenameZWDVW
What is the bag for?
You could also call the toyota dealer and get the pricing on one. The Walbro's are about 100 bucks, as mcg33 mentioned, but you really dont need one unless you're upgrading your whole fuel system.
bigeasy043
08-23-16 10:58 AM
