starting problem.. need help
I have a 99 es 300 with 90k. recently when I start the car, I need to keep my foot on the gas or it will stall. it is fine once i get going . Im concerned because usually one turn of the key and it fires right up. Please, if anyone knows anything about this type of problem , please respond, thanks in advance
It looks like us both have the same problem. Check this thread out https://www.clublexus.com/forums/sho...d.php?t=298069
http://us.lexusownersclub.com/forums...=throttle+body
The 3vz's have a coolant line running through them, so im just too lazy and uneducated to clean mine, but that post should be all the help you need.
