New Key Wont Start!
I have 1995 ES300- The key opens doors and turns igni
tion but wont start. The 2 front doors will not open? but will unlock. I have to open door from the inside. I got key from recomended web site. Any suggestions?
sounds like you may have more than 1 problem if your doors open from the inside you may have popped the rod off the outer door handle... as far as starting can you be more specific does it turn over but not start??? I have read here somwhere how to program a new key if i find it I will post a link...
Remote Keyless Entry Programming Procedure
(Customer Program Method)
1. Sit in the driver's seat and lock all the doors.
2. Unlock and open the driver's door.
3. Insert the key into the ignition and remove it (don't turn it...just remove it).
4. Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times.
5. Close the door.
6. Open the door.
7. Lock and unlock the driver's door 5 times (with the power switch).
8. Insert the key into the ignition and turn it to the "ON" position.
9. Remove the key.
10.The driver's door will now lock and unlock itself one time.
11.Press and hold the "LOCK" button on the key fob for at least 1 second.
12.Close the driver's door.
13.Open the driver's door.
14.Press and hold the "LOCK" button on the key fob for at least one second.
15.Close the driver's door.
16.Press and hold the "LOCK" button on the key fob. The door will lock.
17.Press and hold the "LOCK" button on the key fob again. The door will unlock.
5. Close the door.
6. Open the door.
9. Remove the key.
I have a 97 Es300 and I'm not sure if it's the same on your year, but I have a factory security chip embedded in the actual key - it is totally sealed in the key head and you can't even tell its there. This is in addition to the remote control) When the factory key is put in the ignition the chip then sends a coded signal to the engine imobiliser and allows the engine to start. On my model, if you just get a key cut from anywhere then sure, it will open the door and fit in the ignition but the engine won't start because there is no chip in the key!!! I have a flashing red security light near the ignition key hole. When the original key with the chip is put into the ignition the red security light goes out signalling that you can start the car.
As I said, I'm not sure if it's the same for the '95's but this could be why you can't start the car.
LEX ES 300
Hi,
As I said, I'm not sure if it's the same for the '95's but this could be why you can't start the car.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
LEX ES 300![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
LEX ES 300
The key for this year does not have a chip in it- the key turns ignition but does not start- I am able to turn on lights open windows ect. Today I put in a new battery and still does not start?
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
If you can't start it with the original key or the new key, then I would be getting a mechanic to look at the engine/ mechanical side of things rather than the key itself or the factory security system.
Hope this helps.
LEX ES300
You said originally that you have bought a new key. Do you still have an old key that starts the engine? (I'm guessing that you don't).![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Hope this helps.
LEX ES300
Hope this helps.
LEX ES300
kino1161OL
GS - 1st Gen (1993-1997)
19
11-07-08 02:12 PM
