Transmission shifting question
When was the last time you changed the tranny fluid?
I just had mine done at 90K service.....I did notice an improvement in shifting.
You may want to try this and see how it is. This cheap solution may solve your problem.
HTH
HTH
they're pretty smoothe on the scale of smoothe stock A/T transmissions aslong as the throttle pedal is not held down much.
in order of what i would do:
check / replace atleast the dogbone engine mount (front mount & tranny mount also pretty easy)
piddle with the kick-down cable. they loosen & stretch over the years slightly
change the fluid & check the level hot, idling on a level surface. should read full.
Or it could be wear and tear on the transmission....
I can feel the gears change from 1st->2nd and its depressing whenever it feels like its going to happen...its like a little nudge
I really need a new tranny right now
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
