ABS/Brake Question
ABS/Brake Question
When I first bought my car the guy mention the brakes not being to well. I've been driving it a year now with brakes that seem fine and I just found out what he was talking about. A squirl ran out and stops in front of my car while I was about 45mph, gives me a look, I hit the brakes and he dashes and countiues across to the other side of the road.
When I hit the brakes I felt a vibration on the brake pedal, a sound that sounds like your riding on a wooden roller coaster, and it seemed like the brake pads were slipping on the rotors. Is it my brakes or ABS??
the brake system has well in excess of 1000psi of hydraulic force in the line. if you were a 12v electric pump and you had to duplicate that. you'd make a loud noise too!
the pulsing is the solenoids closing to let the pressure off the brakes. the front wheels are under individual solenoid control, the rear wheels are paired together on one solenoid.
welcome to ABS 101. if you just want to stop put the thing to the floor and let the computer sort it out. if you're going to manuver... you can get away with not letting tottally off the pedal but remember it's brake on, brake off, turn.
oh... man don't hit the brakes for a squirrel. didn't you see the geico commercial??? they cause wrecks for fun!?!?!? seriously tho natural selection man. if it's not big enough to damage the car, dont risk the car.
So how does ABS work?
1.When a certain amout of force is pressed down on the pedal, the ABS system will rapidly pump the brakes on and off?
2.When a certain amount of force is pressed down on the pedal, the ABS system only allows enough pressure on the the brakes to slow the car down to prevent the wheels from locking up and sliding across the payvment.
Introduction to How Anti-Lock Brakes Work
How Anti-Lock Brakes Work: Anti-Lock Brake Types (the 2nd in the series)
Yes you do stop faster in a straight line without it. However that's not the point of the system It's to keep you pointing frontways, and allowing some level of manuverability while maintining the maximum amount of braking during manuvering.
There's a reason why the SCCA still wants to ban ABS from it's top divisions. It makes cars much, much faster when it comes to diving into corners under braking. (Also why formula cars use it tehehe)
It can be disabled by pulling the ABS fuse, however I STRONGLY advise not doing so.
lexusbexus
NX - 1st Gen (2015-2021)
04-28-16 01:46 PM
