installing subs an amps help!
i dont kno much about this kind of car an stuff an i dont want to mess with it
ok im installin subs an amps
how would u guys install it into a 2nd generation lexus 1995 without changing the HU on it? can u guys list it step by step if its possible?
i heard u dont hav to change the HU on these lexus' i didnt kno if it was true bcuz i lik the 6 disc changer in the trunk
isntalling the sub and amp is easy but installing the cd unit itself is hard
when you install the cd unit, tell them to run the rca wire and the power wire (small remote wire) to the back of the cd player for you and then I can show you how to set up the amp and the sub themselves
You use 2 amplifiers... the stock one stays, you create RCA outs and RCA ins, on the stock amplifier. After that you connect the after market amplifier from the boot to the standard amplifer.. the rear 2 speakers are running from the aftermarket amplifier in the boot, and the rest of the speaker run with the stock amplifier under the seat. The subs run off your aftermarket amplifier in the boot as well, so the aftermarket amplifier will be holding the rear 2 speakers, and the subs. The connection between both amplifiers works perfectly fine, if that's what you want to do, in order to keep your original headunit.
That's a general overview of how it can be done.
Sorry would have posted this here before my internet at my house has been down (damn cable company) Here it is I wrote a complete walkthru on how to hook up subs if you need and more help just post or pm me https://www.clublexus.com/forums/sho...d.php?t=278165
JamesBond1
08-02-10 11:27 AM
got_Remy
03-15-06 09:35 PM
