D2S to D1S retro on ES330 hid headlights
Here is the stock base of the D2S.
Here is the filed base for the D1S.I used a electic sander and a hand file.
Stock with screws removed. Like aways the brackets where done on our Waterjet machine.
The Bracket to get mounted on the SC430 bowl. I also mounted them on RX330 and ES300/330 projectors.They may work on others.
I left the top hole oval,just incase I needed to move it.But all the bowl I used where the same.
Ready to install the D1S bulb.
Perfect fit.
I used the same clips from the D2S bulb holders to hld the D1S.So don’t throw them away.
As you can see they are about the same size as the Audi A4 D1S projectors.
Perfect fit.
Back shot of the Bracket.(SC430)
(Audi A4) Back shot.
The bottom bowls are from the ES330 projectors.
ES330 with the D1S brackets conversion.
ES330 trimed.
Now just need to install them in my car.he he
ES330 trimed.
They are mading a comeback.I have noticed that they are been used on the new cars for a couple of year.They say they have longer life span then the D2S bulbs.The piggyback igniters may have sothing to do with it.I may be wrong. The reason I did it was to show it can be done.I have two set of D1S bulbs and now I can use them on my D2S projectors.
Thats just the igniter.The ballast is compact.but their are bulky to slim ballast. I think the corvette C6 has the slimest ballast.Its the same thickness as my razer
http://halloweenbash4.com/corvette/img_4544.jpg
http://halloweenbash4.com/corvette/img_4545.jpg
link to more pics http://halloweenbash4.com/corvette/
tommyGS3
12
10-04-11 01:12 AM
