Rear Struts popping. Need help
hey guys im new to the forum and i have a 1994 es300.
Ok my problem is that i replaced my struts with struts from the dealer and after the install, the rear strut assemblies are making alot of nosie when hitting bumps on teh road. It sounds like somethign is broken. Also to mention, When about 3 people are in the back seat, the rear of the car sags alot and if i go over bumps a little too fast, you hear the tires hit the fenderwell on top.
Well my conclusion is that the springs are probably no good? Does anyone else have any other opinion? Thanks in advanced.
are you positive that that is the noise? because before changing the struts, they didnt make any of those noises.. i double checked everything for tightness. I thought it was like a broken spring or something.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
It might be but I doubt it. Did you put new bump stops in?
