Are Strut mount plates neccessary?
I just got some gabriel strut mount plates in the mail today and after opening them up......I realized they're just metal plates with no rubber parts. It didn't even have the bearing on it.
I was hoping it would help with the noises i'm getting but now i'm really wondering if it's necessary to replace strut mounts......
I cannot see any part of the strut mount plate where any wear and tear can occur.
So when ppl mechanics tell you to replace strut mounts along with struts....do they mean the strut mount bearing or the strut mount plate?
![](http://partimages.genpt.com/partimages/517882.jpg)
Hi Maniax,
I recently bought a pair of Factory Original Strut Mounts and at first I thought that they had no rubber parts either. Upon closer inspection from the top of the mount I could put my finger in the top opening and there is a large but firm rubber portion inside - it felt like metal at first but I can just depress it slightly and it is rubber.
Not sure about the ones that you have though. I know that if you look at mine from the bottom as in your picture there is no rubber parts to be seen/felt either!
I suffer from the front end noise as well and I am convinced it's the mounts (I have done A LOT of researching this on the internet) but in my case I haven't been able to install them yet because I also have to get new struts as well - coz one of them has a very slow leak!![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
I'm up for a min of $1,000 just to replace the front struts here in Australia
LEX ES300
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
LEX ES300
I think its gotta be the bearing going bad, and making the noise. Not 100%
I would change the bearings as well. Not sure how much if you get it separate, but the front mount w/bearing at autozone is going for $60
Hi Maniax,
LEX ES300
LEX ES300
Looks like i will be replacing the mounts and the sway links.
For your struts, if your factory struts are serviceable, you can just buy the refill cartridges on ebay for very cheap.
like this one:
http://cgi.ebay.com/ebaymotors/Gabri...spagenameZWDVW
thanks for the advice! I FOUND IT! i looked at it again closely and could not find a difference but then i started poking different areas with a scissor and YES there is a big rubber portion inside the mount. It's very firm but i'm sure it's not metal.
like this one:
like this one:
That's great Maniax,
Glad I could help you out - I love these forums! I have learnt so much from this site, and in return I have been able to help others as well.
And thanks for the link to the struts. I will have to see if mine are servicable.
If you are replacing the strut mounts, you might as well replace the small bearings that fit under them as well. They are not very expensive, so you might as well do them at the same time.
Lex ES300
Lexucanafer
I replaced the front sway bar bushings a while back and the noise I'm hearing now isn't the same sort of clunking noise I used to hear.
I too have the squishy rubber noise and the clunking noise in the front of the car area. Is the squishy rubber noise the sway bar bearings and the clunking noise the strut mount bearings? I'm currios cause I was just going to get struts/shocks and springs to fix this problem but if this is the case, may as well get the sway bar bushing done at the same time.
Lexucanafer
Lexucanafer
Yodog (12-14-23)
TTBomB
04-09-19 01:01 PM
jeanD1010
11-13-17 06:54 AM
Eliaquim
08-09-14 06:55 AM
