car wash, engine cleaner
ok at some car washes they have where you can spray your engine and engine bay off and some cars you cant do that
was wondering if a 2nd generation es 300 could be sprayed off cause i would like to have a cleaner looking engine but was afraid to mess something up in my engine? any suggestions im no car genious but i was at the car wash doing it myself and i was looking at it
I thought you couldn't do that...but if that's the case then use engine de-greaser and rinse away with a pressure washer... and avoid the rubber parts of course.... or a steam washer.
I would not dare to wash my engine with a spray hose.
You might like to try some diluted Simple Green in a spray bottle and some rags and get to wiping. Gunk's not a bad idea either.
Earlier I was fixing the spindle assembly to the toyota van, and I got all greased up and dirty... my uncle had some Kirkland signature laundry detergent and sugested that I use it to clean myself... and it WORKED! It worked better than that orange gojo stuff (and other auto hand cleaners)that I always used.. I don't know why but it washed away clean.
Lexucanafer
I agree. Simple Green for cleaning the greasy stuff, and then put a coating of 303Aerospace protectant on all rubber and plastic parts, like hoses, air filter cover, fuse box, etc.
Found my old engine thread too. Its not perfect but I didn't have a spare toothbrush at the time haha
https://www.clublexus.com/forums/sho...ghlight=Engine
I have been spraying down my engines for years and never had a problem. High-end detail shops use boiling water so it dries when it touches the engine. You can use a pressure washer, but just make sure the engine is warm and the water will dry very quickly. Then drive the car and get the engine compartment up to a high temperature.
Of course something could happen, but in most cases, it will be fine.
Yes I've heard about the warm engine thing... but I also heard of the HOT engine, cold water comes into contact with HOT, and heads expanding... then blowing up. Not too sure if it's true.
Isnt the engine cleaner at the car wash also "tire/wheel cleaner"? You are definitely better off taking a saturday or sunday morning to spend some time detail cleaning it with purple power or simple green at home. If you have an aftermarket air intake, cover the filter with a plastic bag.
depending on the the level of heat and object thats being cool.
AndyG
15
03-02-11 10:01 PM
