Adding IPOD and/or XM to 97 ES300
Old 01-25-08, 06:39 PM
jtsosie
jtsosie's Avatar
Doing this mod without the CD Changer?
As I've read, you need the CD Changer attached and functioning so the deck will recognize it and keep the CD selection selected. You might test it to be sure, but I imagine the deck will still have the connections even if you don't have the CD Changer.
Old 01-25-08, 06:58 PM
jimmyjay
jimmyjay's Avatar
Originally Posted by NovaRacer
I bought this ipod attachment at circuit city.
Installing it this weekend, let you know if it is worth the $.
NovaRacer,
Any luck with the Circuit City interface?
Old 01-25-08, 07:23 PM
jtsosie
jtsosie's Avatar
I ended up having to cut 2 holes with my Dremel. The first one was 1/8" too far back. The mount for the wood trim was just barely in the way, and I didn't want to cut it. Also, I had to move the final slot forward enough so that there was enough wood material to brace the iPod mount to.
I'm letting y'all in on my secret. To everyone else, that's my standby mount (when I don't want the iPod connected).
Attached Thumbnails Adding IPOD and/or XM to 97 ES300-100_0629.jpg
Old 01-25-08, 07:25 PM
jtsosie
jtsosie's Avatar
It was tough deciding where to mount the iPod. I wanted it visible so I could change songs and view info easily and constantly.
When the drink holder is down, the top half of the iPod is covered. I decided to live with that.
The drink holder can still be opened and closed without touching the iPod.
Attached Thumbnails Adding IPOD and/or XM to 97 ES300-100_0630.jpg
Old 01-25-08, 07:41 PM
jtsosie
jtsosie's Avatar
Here's the underside. The mount is created from a metal bracket which is screwed & glued to the wood trim. The iPod cable is glued to the metal bracket.
I put on the glue and tie-wrapped the cable in place and then connected my iPod so it would dry in the position I wanted it.
The glue is Gorilla Glue. AWESOME stuff! The tie-wrap could be cut off now.
Attached Thumbnails Adding IPOD and/or XM to 97 ES300-100_0631.jpg
Old 01-25-08, 07:43 PM
jtsosie
jtsosie's Avatar
Oh yeah. One last thing.
The iPod cable had metal clips which attach to the iPod. I shaved those off since I would need it to come off when I pulled from the topside. It's plenty tight without them.
>>That way you don't have to pull off the wood trim to squeeze the sides of the cable to release the iPod<< heheh
Old 01-25-08, 08:07 PM
Choas
Choas's Avatar
Wow now that is so simple it has to work why hasn't anyone thought of that before. Now how do I record a "blank" cd?
Old 01-27-08, 09:43 AM
jtsosie
jtsosie's Avatar
You can use Sound Recorder to record a blank piece of audio.
Start > Programs > Accessories > Entertainment > Sound Recorder
Press record with nothing plugged in to your audio input and nothing playing on your PC. A few seconds is all you need.
Then save it as a .wav file in this format:
PCM 44.100 kHz, 16 Bit, Stereo
Now burn an audio CD with that file. Ta-Daaa!
Old 02-15-08, 10:13 AM
Imola.zhp
Imola.zhp's Avatar
Update from Nova?
This tape-connector just isnt cutting it...
Nova, what iPod/iPhone will you be using? Does the packaging from the MFG by chance say it will work with iPhone? My BMW kit is fussy with my iPhone =(
Old 02-15-08, 03:16 PM
Slooooooow
Regional Officer - NTL
Slooooooow's Avatar
Cool
Originally Posted by Imola.zhp
Update from Nova?
NovaRacer, don't leave us hangin', man. I've found these online and am ready to pull the trigger, one for each car, the moment you tell us it works.
Old 04-03-08, 12:54 PM
Choas
Choas's Avatar
Gotta bump this thread. jtsosie if your still around what kind of switch did you use. I'm not to up on my switches even tho I work at RadioShack. I need a rocker that would break the two wires at once which on did you use?
Old 04-07-08, 08:05 PM
jtsosie
jtsosie's Avatar
Hmmm...
You can see the rocker side in the pic on the first page here.
The switch is a DPDT switch. I think that is Di-Pole, Di-Terminal.
There are 2 terminals in the middle which are always connected at the switch. There are 2 terminals on either side of the middle. When the switch is slanted to the (let's just say) right, the terminals on the right are connected to the middle. When the switch is pressed to the left, the terminals on the left are connected to the middle.
...anyone need a diagram???
Old 04-07-08, 08:09 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
surprised nobody linked here yet
https://www.clublexus.com/forums/sho...d.php?t=269156
Old 04-07-08, 08:16 PM
Choas
Choas's Avatar
Originally Posted by jtsosie
Hmmm...
Hmmm still kinda confused I could use a diagram if you don't mind. On another not is that a RadioShack DPDT switch. Also can't this also be done with a SPDT switch?
Old 04-07-08, 08:17 PM
Choas
Choas's Avatar
Originally Posted by PureDrifter
Now you can add one more Lexus model to your confirmation list. And yes I saw this before while doing some searches for this but since it wasn't confirmed I didn't think to try it.
Quick Reply: Adding IPOD and/or XM to 97 ES300
