how to access the rear tail lights
Old 11-24-07, 04:16 PM
96Lexboy
96Lexboy's Avatar
Default how to access the rear tail lights
does anyone know how to access the rear tails lights, so i can change the bulbs and the license plate bulb?
Old 11-24-07, 06:37 PM
92ES5sp
92ES5sp's Avatar
Im assuming you have a 96. First remove the long plastic trim piece on the top of the deck. It just unsnaps. Then remove the 4 phillips clips things and the 2 round clips at the bottom of the cover, they pry right off. Take the cover off. Then you will see I think half a dozen or so 8mm nuts holding each taillight assembly in place and you can take them out from there. The plate bulbs are 194.
Old 11-25-07, 02:32 AM
Lexucan
Lexucanafer
Lexucan's Avatar
Here are instructions (with pics) for a '94 but a '96 should be the same. There are 4 nuts to remove for each tail light assembly. The bulbs are 1156, 1157, and 168.
So, 96Lexboy, where are you located in B.C. ?
Old 11-25-07, 10:42 AM
96Lexboy
96Lexboy's Avatar
thanks guys, that sure was a lot of help
btw lexucan, im in Surrey.. yeah i know its hurt lol
i see ur from vancouveR?
TjsLS400
05-28-16 08:01 PM
kowala
09-23-14 10:48 PM
ted920
05-26-11 12:19 PM
pudieinpa
SC- 1st Gen (1992-2000)
12
08-14-05 04:43 PM
jhbhatia
03-24-03 08:36 PM
Quick Reply: how to access the rear tail lights
