cold car stalling after putting in gear
past 2 days when the car is cold, i start it and put it in gear after about 10 seconds.
it stalls as soon as it is put into r or d.
i restart the car and try again, after the 3rd try i give it a little gas and it still does it.
after the 4th try it goes.
a few months ago i replaced the plugs and af/ sensor and canister. i know the latter are unrelated but is it possible that the throttle body needs to be cleaned or the cold start sensor is bad?
no codes
no codes
Well, heres what i recommend...
First check for any vacuum leaks. It might be as simple as a cracked hose or tube.
If that seems find the you might have a dirty IACV, TB, EGR, manifold, blah blah blah blah.. Get yourself a can of TB cleaner and take everything off your intake manifold and clean off all the carbon build-up, try to clean up inside the manifold while you're at it. If that doesn't fix it, then you might have broken something.
Good luck!
Good luck!
GS300noob
04-27-12 06:55 AM
