Need correct tire size for new rims
I'm replacing my 97 ES300 factory 15" rims with a set of 2001 Platinum Edition 16" rims. I'm trying to determine what tire size should I get to keep the speedometer accurate. I've been told this is a concern when upgrading to larger rims.
The Lexus Parts Dept. says 205/60r16. This is also the size I saw on another set of Platinum Edition rims. However, most Tire companies like Discount Tire, Tire Rack & Costco recommend a 215/55r16 tire for "plus sizing".
Any experts out there willing to set the record straight, or at least shed more light on the subject?
Thanks,
John
Thanks,
John
Lexus Connoisseur
You shouldn't have a problem with plus sizing. You are usually within a small margin error which really won't make much of a difference. If you insist on the exact size, I would suggest that you request the exact size. Most tire shops will be able to order that size from their tire supplier. A benefit of 215 vs 205 is a wider tire (i.e. better handling).
Quick correction:
Here are the units:
P205mm/65% r 15in
ml is milliliter, a unit of volume (also interchangeable with mg, a unique feature of the metric system).
Quick translation of the tire size code:
P205/65 r15 87H
P: passenger car (LT for Light Truck)
205 is tire width in millimeters
65 is the"aspect ratio or profile". This means the tire wall height is 65% of the width
15 is course rim diameter in inches.
87H is load rating with an "H" speed rating (up to 130 mph), V (up to 149 mph), Z (149+ mph), S (up to 112 mph), T (up to about 100 mph), & Q (up to about 85 mph; usually seen on snow tires)
Here are the units:
P205mm/65% r 15in
P205/65 r15 87H
Thanks to all for the helpful responses. It appears that either size tire will not affect my spedometer which was my main concern. I believe I will go with the 215's because of the wider foot print.
- John
- John
Lexus Connoisseur
Originally posted by cperez100
Thank you all for your responses. This is one question I had and I even post it but nobody replied. That was when I was new here @ CL.
Thanks again.
Thanks again.
