Passengers Side Mirror :(
Im having problems removing the preivous mirror, you know the black leather type pannel, one of the bolts is behind that and im not sure how to take it off, also connecter is behind it so how do i remove it?
It looks right. The wires appear to be the correct colors according to my wiring diagram. might as well give it a shot. Shouldnt take more than 15-20 minutes.
In that case the door panel needs to be removed. You will need to remove the plastic cover inside, behind the chrome inner door handle. Pop out the window switch plate, and remove the bolts behind those items. I believe that is it for the bolts that hold it on. Then you will need to get behind the panel with your fingers and give it a quick pull to undoo the clips, Once the clips are released push up on the panel to release the top of it from the door.
HINT:
Installation is in the reverse order of removal. But the installation is indicated only when it has a point.
In the RH side, work in the same procedure as in the LH side.
REMOVE POWER WINDOW REGULATOR MASTER SWITCH ASSEMBLY
Using a screwdriver, remove the power window regulator master switch assembly then disconnect the connector. HINT: Tape the screwdriver tip before use.
REMOVE FRONT DOOR LOWER FRAME BRACKET GARNISH LH
Using a screwdriver, remove the front door lower frame bracket garnish. HINT: Tape the screwdriver tip before use.
REMOVE FRONT DOOR INSIDE HANDLE BEZEL PLUG LH
Using a screwdriver, remove the front door inside handle bezel plug. HINT: Tape the screwdriver tip before use.
REMOVE FRONT DOOR TRIM BOARD SUB-ASSEMBLY LH
Remove the 2 screw.
Using a screwdriver, remove the front door trim board. HINT: Tape the screwdriver tip before use.
Remove the inside handle then disconnect the 2 cables from the front door lock assembly.
Disconnect the connector.
REMOVE FRONT DOOR SERVICE HOLE COVER LH
Disconnect each connector and remove the front door service hole cover. NOTE: Remove the remained tape on the body side.
REMOVE FRONT NO.1 SPEAKER ASSEMBLY
Remove the 3 bolt and the front No.1 speaker assembly.
Remove the 2 screw.
