Timing Belt Servicing
Old 12-31-07, 12:38 PM
Two bit
Two bit's Avatar
Default Timing Belt Servicing
What would you suggest, 90k or 100k tune up on your timing belt. I did mine first at round 60k, but I am used to hondas so it's every 60 and 100k. Thanks for the help guys
Old 12-31-07, 12:56 PM
JSM1284
JSM1284's Avatar
I believe the book calls for 90k, I did mine along with Water pump, Coolant flush, spark plugs at 100k.
Old 12-31-07, 06:54 PM
Rollin'ES3
Rollin'ES3's Avatar
Book says 90k for major service w/ timing belt. You can go 100k without any problems though.
Old 01-01-08, 10:37 AM
Two bit
Two bit's Avatar
Well, my steerings real wacky, whenever I do a u turn or something, it squeels real bad. What could it be?
Old 01-01-08, 01:07 PM
Rollin'ES3
Rollin'ES3's Avatar
Probably might need a flush of the lines, cause it might be air in the system. Hopefully that fixes it.
Old 01-02-08, 08:26 AM
llcoolpass
llcoolpass's Avatar
I rec R&R the belt sooner than 105K -- @ 60K, and then doing it again along with the water pump and the idlers/tensioner at 120K.
ALAN553
GX - 1st Gen (2003-2009)
10-29-17 06:09 AM
weyless
03-01-13 10:32 AM
UNOHOO
IS - 1st Gen (2001-2005)
06-04-09 11:59 AM
dumdumgreg
06-16-06 02:55 PM
Och
05-15-06 08:01 PM
Quick Reply: Timing Belt Servicing
