19x8 rims with a 1.80 drop work???
I've got 19x8.5 rims with a +45 offset all around. I ended up having to put 15mm spacers in the rear because the rim pushed up against the strut bar.
I don't see why 19x8 shouldn't work . . worst comes to worst you'll need to throw in a few spacers
I got the 15mm hubcentric spacers off ebay, the longer studs came included. I think they're made by Ichiba ?
i dont think they make hubcentric spacers. spacers yes. hubcentric rings yes.
sash- you have a rear strut bar? i think you mean strut/shocks?
you can use spacers, but ive personally never been a fan of spacers. some run with them all day. i personally dont trust them.
Charley
Charley
Charley
Charley
Exactly the ones I bought.
My rim was pushed up against the bar/arm of the strut resulting in the car not being able to move.
Yea my problem was that I have the longer studs and need just the spacers. Idk what thy did to put those stud in but I remember mine being a pita. Did you see them do it?
From what I remember he hammered out the old studs then put in the new ones, wasn't hard at all.
Thats what we did you just needed top have strong arms (which I do not) and have to take the brakes off. Anyways have you seen just the 15mm spacer without the longer studs.
I originally tried seeing if the car would move with 5mm spacers and I hardly had any tread left for the lugnut . .
just get the adapter ones from 5*114.3 to 5*114.3. because they are adapters it should have the new studs in it already.
and strong arms wont loosen any studs. its the right tools, or tools if you use your imagination like i said.
ie, use a deep socket 19mm socket and a c-clamp for removal. for reinstall use an open end lug nut. simple.
charley
charley
