Which Tires Would I Need?
i dont think its the rotors, im almost 100% positive its for strut clearance. because sc's are rwd, thus meaning more backspacing(a lot more usually) than what fwd cars(like ours) have. you should be ok with a 225/40/18, but if you want to play it safe, then go with 215/40/18. and you will need some spacers. approximately 3-5mm.
btw, more specs on your suspension setup may be a little better for us to help decide what will work/not work better
Charley
Charley
When you drop a car, you get camber which helps if you're fitting wheels. I doubt you're going to drop your car low enough unless you get coilovers so you shouldn't worry about it. Just get 225 to be safe.
I don't remember where I read about them clearing the rotors but here is some other CL members experience with sc430 rims.
https://www.clublexus.com/forums/sho...430+wheel+club
alaskaty
01-31-08 05:41 PM
