all the needle on the cluster are stopped working
Old 01-12-08, 11:03 PM
shuiyuan
shuiyuan's Avatar
Default all the needle on the cluster are stopped working
they were working fine but today i took the whole cluster off and tried to clean it after i put it back all the lights on the needles are stopped working.
Old 01-13-08, 12:32 AM
Rollin'ES3
Rollin'ES3's Avatar
Id check the fuse. Maybe you shorted out the fuse while removing/reinstalling.
Old 01-13-08, 09:14 AM
shuiyuan
shuiyuan's Avatar
is there a fuse for the needle lights only? all the back lights are working on the cluster
Old 01-13-08, 09:42 AM
BadViper22
BadViper22's Avatar
You probably didn't plug in the wire harnesses to the cluster all the way. Go back in and push them in nice and tight.
Edit: There's three wire harnesses and since the back lights and everything else are working, chances are one isn't making contact with the cluster, give em all a good push.
Old 01-13-08, 09:49 AM
Rollin'ES3
Rollin'ES3's Avatar
Oh I thought you meant all the lights were out. Oops
Yeah like said earlier, check to see if you have it plugged in all the way.
What year is your ES?
Aren't the 2nd gens known for having their needles burn out?
Old 01-13-08, 10:46 PM
shuiyuan
shuiyuan's Avatar
i checked the harness, pushed hard to make sure they are in the slot but still no luck. my car is 94
Old 01-13-08, 11:08 PM
esucaris1
esucaris1's Avatar
make sure you didn't bend any of the contacts on the plug receptacles also check the plugs for contacts that might have slipped out of the plug...
Old 01-13-08, 11:30 PM
swifty562
swifty562's Avatar
i agree... theres two contacts on the needles between the middle holder.
looks like this []0[] there could be a possibility that you might of bent the metal.
Old 01-14-08, 12:13 AM
Lexucan
Lexucanafer
Lexucan's Avatar
What did you use to clean the cluster when you removed it? If you used some type of liquid, could some of it have gotten inside the cluster and shorted something out? I'm having a little trouble understanding why you would remove the cluster to clean it in the first place. Maybe it would be easier to figure out what happened to it if you could explain in more detail what you did to/with the cluster once you removed it from the dash.
Old 01-16-08, 08:33 AM
srvcm
srvcm's Avatar
I agree with Luucan... also is it just the needles and all four or is it just one or are all of them out? Ive examined the daughterboard of the 92-96 lexus instrument cluster and find the fuel and temp guage get power from 5 screws located on the back of the cluster. The Speedo and Tach have two long pins that protrude into the contact slots of the board. Spraying anything on to the guage face is sure to have shorted out the electronics and your only fix may be to have it repaired or replaced (if you cant fix it yourself)
Old 01-16-08, 12:26 PM
shuiyuan
shuiyuan's Avatar
just the needles, all the back lights are working. here is what happened, the last owner saw there is a light bulb on the back burnt out, he said he opened the gauge to change the bulb, when he puts back the temp and all needles stopped the working. after i bought it i took out the cluster and checked everything, i found that he didnt screw 2 screws on the back of the guage which are for singal of the gauge. after i put it back the temp works again but the needles still dont work.
Old 01-16-08, 12:28 PM
shuiyuan
shuiyuan's Avatar
i hate when people who didn't know about cars but still want try to fix something to cause problems on cars. a lots screws have been lost on the cluster.
Old 01-16-08, 01:37 PM
Lexucan
Lexucanafer
Lexucan's Avatar
Could it be that the gauge needle LEDS are burnt out, which is very common with the 2nd generation (92-96) ES300?
Did you see that the gauge needles were lit up before you took the cluster out? Your first post would suggest that they were working, but your later post suggests that they haven't been working since the previous owner played around with the cluster. Not sure which is correct.
Old 01-16-08, 06:56 PM
shuiyuan
shuiyuan's Avatar
sorry that i posted everything the last owner said on the first post when i go buy the car, that he said he was trying to clean the gauge. when i saw there are some reply above that want me provide more details then i called him again today and asked what did he really do then he told me another story today.
mluvls400
12-16-12 09:58 AM
groverwood
SC- 1st Gen (1992-2000)
18
10-04-12 08:27 AM
bmsc300
03-30-11 05:26 PM
mr29rose
06-19-10 05:57 PM
JAPPILAC
03-23-09 06:33 AM
Quick Reply: all the needle on the cluster are stopped working
