Type T IV or mobil 1
Old 01-21-08 | 08:34 AM
  #31
Lexmex's Avatar
Lexmex
Super Moderator
You may want to ask them and see if by luck the have a distributor in Manila, webmaster@amsoil.com
Old 01-21-08 | 09:10 AM
  #32
arnelli's Avatar
arnelli
Thank you Lexmex!forgot to mention , my overdrive doesn't function. What should I check
Old 01-21-08 | 09:22 AM
  #33
Lexmex's Avatar
Lexmex
Super Moderator
do you have check engine light or did you just sense it?
Old 01-21-08 | 10:59 PM
  #34
arnelli's Avatar
arnelli
no check engine light. When I press the overdrive button nothing happens and indicator light does not light up
Old 01-22-08 | 03:38 AM
  #35
Lexmex's Avatar
Lexmex
Super Moderator
When you drive, do you notice anything different, in other words when did you first notice you didn't have overdrive?
Old 01-22-08 | 01:30 PM
  #36
arnelli's Avatar
arnelli
hmmm just got home (5:27 am here )and tried pressing the button on and off..there seems to be a difference, but I need to do more driving to truly give a more reliable report. you think the overdrive bulb is just busted?
Old 01-22-08 | 08:08 PM
  #37
arnelli's Avatar
arnelli
by the way , does this 1992 model have a cabin air filter? in case it has one, how do I replace it?
Old 01-23-08 | 12:27 AM
  #38
smokesgtp's Avatar
smokesgtp
Nope it doesn't. They didn't have them until 99', had the space for one since 97'. The light could be burned out thats possible, is it running at lower rpm's at a steady crusising speed when the button is pressed in?
Old 01-23-08 | 05:08 AM
  #39
Lexusfreak's Avatar
Lexusfreak
Cool
Originally Posted by arnelli
oh PITA..ok now I know hehehe. hmm im intrigue with this amsoil. I think i´ll go through the PITA experience and find a way to have it for my es300. How many liters do I need?
You will need 4 quarts.....it should take about 3.5 for the drain & fill give or take.
The Amsoil ATF also is fantastic stuff for the power steering fluid (which takes ATF). The easiest way to switch out the old power steering fluid is to get an empty spray bottle & put the hose in the reservoir & pump out the old stuff. It takes about 1/3 - 1/2 of a quart.....so you might want to get a total of 5 bottles.
I also bet that if you contact Amsoil directly, you will be able to find a distributor closer than you think & not have to order directly from the U.S.
Old 01-23-08 | 05:55 AM
  #40
arnelli's Avatar
arnelli
smokesgtp
the button won't press in. Touches like a doorbell. you press and it just goes back to it'soriginal position.
lexusfreak
for the meantime I poured in toyota type VI.Runs well. and a lot cheaper. But i'll get in touch with amsoil
Thanks again guys!
mitsuman
06-14-16 08:17 AM
McMuffin
09-26-15 07:36 PM
Vinylpro
02-20-14 03:33 PM
copy252
05-14-06 04:06 PM
Quick Reply: Type T IV or mobil 1
