i need help please asap i beg u! (car turns on and right off again)
this car is possessed i need help awhile back the car's throttle got stuck and ever since then it hasnt ran.. we have replaced the TPS the spark plugs and now it turns on and right when u turn it on it shuts off right away.. i re checked the spark plugs and they seemed burned again and they are new. seems its burning to much gas.. is there anyone outhere that can help me out like i said before it just turns on and turns right back off
btw the check engine light is on too and its a92 es300
Indeed, bring us a CEL code for specified help. llcoolpass and 92es5sp were right, check the intake tube and AFM. Also make sure your IACV isn't clogged completely closed. Can you start the car and keep it going with your foot on the gas?
can someone show me a pic of the air flow meter?? and yea if i keep the foot on the gas it will stay on also
im sorry kinda a knoob whats a IACV and where is it located?
thanks so much guys i hope to keep geting posts from u guys
awesome man thanks its throwing out 2 codes code 24 and code 31....code 24 i think is the IAT sensor and the 31 is the AFM sensor right?
thanks alot for the pic man i hope these are the ones
Indeed they are. Is the car stock, or do you have an intake kit of some sort? Anyway there is no code for a 92-93 IAC problem that I know of so make sure that is clean and functional. And the airflow meter is 96% the problem like llcoolpass said. So granted wiring is good especially if its location was distuberd, drop the $250 for a new one and youll be done w/ it. Its 16 years old. It will at least run after that. Good luck. Id chuck the hose right from the get-go if its factory.If it ran crappy for a while in the past, id throw 2 o2 sensors at it for peace of mind. Keep it goin w/ updates!
Edit: BTW i gotta ask is the airflow meter plugged in?
