problem with ?????
problem with ?????
Sorry I havent been on in a while but have a problem with the right front rotor rubbing agaist the brake pads when I hit 55-80 i have really bad vibrations but once I hit 80 it starts to go away help
i replaced the brakes and rotors and after the same thing happening i noticed one of the pads is all the way against the rotor while the other isn't. and charley is that ur car in ur signature?
I have the same problem, i just rule out break pads, rotors, and axle.
after intensive break bleeding, car test drives, ( more than 5 times )
I figure it was the caliper..
slight movement is okay (back and fort, towards engine) on the rotors without wheel on, about a quature of an inch. because when you put the wheels on it'll be tight on.
remember, the break pads holds the rotor along with the wheel and lug nut.
anyways, i installed my front passenger wheels and no movement. * good *
so i did my front driver side, bleed and bleed and bleed again.
i notice there was more movement then normal. so i check brackets, nuts, etc and everything is there. also, i check break hose for any leaks or loose nuts. ( none) okaay... so i scratch my head * shrugs *
i thought * hey maybe its okay and put the wheel on and it'll tighten up *
**wrongo!**
i installed my wheels and there was so !!double trouble!! and double the movement!!! * BAD BAD BAD* i'm not even kiddin.
i put my car back on the ground and u can totally tell that the wheels looks like its going to come off.
in short, ive come to conclusion that i have a fualty caliper.
i just waiting for "pickaparts" 50% off yard sale so i can pick one up.
about $15-30 for a use one.
**wrongo!**
**wrongo!**
i put my car back on the ground and u can totally tell that ****the wheels looks like its going to come off.****
**wrongo!**
well...i figure out the vibration. it was because my bolt to the axle was simi loosen on my driver side. (dangerous)
but still have a problem... i get really weird sqeeky and rattling noise from my passenger side....
realllyyyyyyyyy louddd.. like something scratching or banging.
so its a big problem.
when i figure that out i'll fill everyone in on it. but if anyone have a clue on this let me know.
so huerdo623, i suggest taking off your wheels and check rotors, brakes, pads, bolts, etc to see if anything is loose or broken.
my god am I dumb my cousins girlfriend found the prob. It was a split rear tire,which I have been driving 80+ m.p.h on the freeway for the past 2 weeks
it is always the simplest ones
OKC06IS250
Suspension and Brakes
05-06-19 01:22 PM
