Will A 1.6"drop Be Too Much On A 96 Es300 W/18" Is350 Wheels?
^I don't have mine rolled/shaved and it doesn't rub on the fender. Now if you do go that route I would undercoat the area so you don't rust where you shaved it. Now I have 225's all around on mine they are the closest to stock height and the tires in the rear still look kinda small on the rim (width wise). Now changing a chamber plate what does that entail?
you just hace to find some camber plates that are made for your year and make. TEIN maybe? your strut would attach to the plate via a strut nut. idk my jic are all built together on the 240.
i could have sworn i saw some somewhere. ill do some searching too. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
edit: i could not find any
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
