--- Why would I be running Rich??!? ---
Well it is a 1993 so it is OBD1 (all pre 1996). And I searched and I think code 25 is rear oxygen sensor right?
Also, my relay for the fuel pump is not there... isn't there supposed to be one there?!? (in the engine fuse and relay box)...
yes, propane torch is how you clean the element
if you searched you would have seen my post saying what the code for the rear is
yes the rear as in firewall side as in the right bank 02 sensor is code 25. you might be getting a dummy code if something else is wrong with the car, though. hence I am trying to work with you and you're all over the map.
ill try again and then i quit: did you change the oxygen sensors as required per maintenace (have they been used for well over 60K miles)?
do you see any cracks in the intake hose?
-brian
-brian
This thread is so confusing....
I cant even tell if you have codes or not. Here is the fix: Change the o2 sensors, clear the codes, fill your tank, drive the car. If you still have the factory sensors in there they are definitely no good anyway. The issue dosent need to be so over analyzed. How does the engine run? Good?
