How to disengage VSC (?)
I ran across this in a review of the IS250 in Car and Driver:
"And for that occasional run through the woods, when you’d rather not have the electronics interfere with your tire-sliding ambitions, here’s how to shut down the stability system. Start the car with the hand brake engaged. Press the brake pedal twice and hold. Engage the hand brake twice and hold. Repeat until the “skid lights” appear on the dash. The ABS does not shut off. When the engine is subsequently turned off and then switched back on, the stability control is reactivated. (Presumably, this trick works on all new Toyota and Lexus models, and it’s easier than it sounds.)"
I wonder if it would work on the 05 ES330 or later models? I am not bold enough to challenge my car to try to find out. Has anyone tried this?
Boston Snowboarder
05 ES330 Silver/Blk
99 Honda Civic LXBlk
04 Subaru Outback LTD Blue
Boston Snowboarder
05 ES330 Silver/Blk
what year is250 was that for, boston? are you sure it's not the traction control system you're trying to disengage or that car & driver is referring to; if so i'm sure you know where the button is for that..why would you want to disengage the VSC?
I'm still trying to find out on another post if my 2000 ES300 HAS VSC
whereabouts in boston are you, i'm from the area.
As far as your question, I cant answer it for 2000. I know that for 2005, as far as a know, all cars that had VSC had trac and vice versa. So it was easy to tell which car has VSC/trac just by looking for the trac off button below the ignition.
I am pretty much right in BOston, in the city.
Boston Snowboarder
2005 ES330
2004 Subaru Outback
1999 Honda Civic
xbladex00
05-07-15 02:10 PM
