Change wood steering wheel in my1998 ES300
Hello all, I purchased a factory wood wheel from a 1999 ES300, it's even the right color (lucky me) and my old airbag should fit onto this wheel, I hope? I want to install it into my 1998 ES300. I will disconnect the battery before disconnecting and removing the airbag. I am worried about triggering warning lights when I reconnect the battery after installation of the 99 wheel. I also cannot find the airbag fuse? Any helpful hints for me with this install. Thanks
Hope this helps, it's for a the 2nd gen ES but shouldn't be too different to our 3rd gen ES. I found this in the DIY sectoin of our the Clublexus ES Forums. How to change the steering wheel in your ES
Oh, and by the way..........welcome to Clublexus!!!!!!!!!!!!!!
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
A couple of helpful hints:
1. Prior to disconecting the airbag, you should align the wheels straight.
2. Make sure have the steering wheel puller from Autozone or do this swap in their parking lot - its a free rental.
3. After you disconect the airbag- DO NOT EVER put the key in the ignition - for the reason that if the airbag is disconected, the key will activate the onboard computer and recognize an airbag error. Now your screwed - have to either reset (pain in the ***) or take to lexus ($80ish bucks). only put the key in the ignition after 1min of reconnecting the neg terminal.
Hope this helps.
There is currently a 2001 ES wood steering wheel w/ black trim on Ebay. Current bid is in the $50 range, and 4 days left in the auction. Better get to it fast for a bargain!
Thank you for the welcome message! I am a little nervous about this. I have read that you can trigger lights and all kinds of stuff but i will try. I am curious about the instructions you gave me. You said "Rotate the center to the left until it is tight. Then move it 2 turns to the right and line up the 2 red arrows." Is this the clockspring I have read about? If I am not removing it what is the purpose of adjusting it? I am obviously missing something here. Please help this novice out....thanks, what a great forum!
Where do I find the DIY section mentioned in the quote above? Don't see anything labeled DIY.
Thank you.
