Front KYB strut mount Bearings Placement??
ahh we were posting at the same time, at least it didn't come out too mangled up, actually, our posts seem to jive pretty good
^most^ of your parts look great, if I wasn't in a terrible $ situation, I would be doing every single part you are, your vehicle will be safer, longer lasting, quieter and worth more. I'm doing what you're doing, but only one little thing at a time when I can.
LEXUS power to ya
edit: that ebay part assuming no typos looks good, I would buy two right now, if you're worried about not having the parts right there in front of you when you do the struts if your old ones are bad and you need the part. not a bad price at all. then, if you get it and you dont need it, obviously you can sell it to someone on here or ebay since they are so in demand.
LEXUS power to ya
So do you think It will work?
check this out do you this will work? https://www.1sttoyotaparts.com/keyword.html
brand new calipers? kinda overkill, isn't it? what was wrong with the prev ones? are those brand new ones aftermarket or toyota?
this is very nice! you obviously plan on keeping this car forever :>
I went to u pull it on federal, they have one lex there if you need anything. though its pretty messed i must say. they have 3 camry there if you need similar parts. the 92/93 camry share a lot in common. the es300 thats there is a 96
parts train is the cheapest source, cheaper than even where i work parttime AFTER my discount!
just a tip for others... 92-94 peoplle with the bearing that goes UNDER the bearing
They are brand new toyota ones that im going to paint black with a lexus decal on them, my old ones were shot. The rears pistons were seized and front right had a bad piston.
RyanV
Suspension and Brakes
12-11-09 08:47 AM
Ariyanna
02-11-08 05:48 PM
